[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
My Sunvell T95Z Pro with LTM8830 has been working great on Superceleron's rom (even without the wifi or bt). About 2 or 3 weeks ago, I starting having issues with Google Play Store stopping at every bootup ("Unfortunately Google Play Store has stopped") causing it to disappear from the list of running services. Even though it stops at bootup, I can still launch the app to download/update apps. I was wondering if any of you has had this issue? I have tried clearing the cache and data of multiple Google apps and disabling and uninstalling third party apps, resetting my app prefs, removing and recreating my google accounts. All with no luck. Also tried to update Google Play store via it's settings by clicking on Play Store Version but it never updates and not sure if that would fix the issue anyway. The only module installed in Xposed is YoutubeAdAway. Thanks.Last edited by jseeley; 21 May 2017, 16:41.
Originally posted by messerchmidt View Postjust reloaded this on a t95k - keep losing root after awhile (supersu stops working, says cannot be found), and playstore crashed message pops up. suggestions?
I have the T95K Pro and I also have the google play store has stopped working. I did everything I know, even got the most current google play store.apk file thru apkmirror web site and updated the play store, this method has worked on my Beelink GT1. But has not worked on this box if anyone has a fix please share.
Nougat 7.1.1 on T95K Pro.... For what it's worth I installed the Nougat rom from the M92S Plus on my T95K Pro. Download link can be found here...
http://chinagadgetsreviews.com/downl...us-tv-box.html
The M92S pretty much has the same H/W, the wifi chip is the AP6330 so it will work if your box has the AP6330 chip. The rom seems to be working very smoothly but with the following issues (if they are an issue for you)...
The front LCD clock on the box is not working
There is no way to configure the home screen (mbox launcher) besides adding apps to the bottom row. Of course I could always install another launcher (i.e. nova)...
Also, I've tried using Flashify to install the TWRP referenced in this thread (which worked when I did it with Superceleron's rom), but no go with this rom... When I reboot into recovery I get nothing....
Still, despite the issues, I think I prefer this rom and will likely just install Nova launcher and not worry about my corrupt recovery partition for now. Perhaps someone out there with more knowledge than I will be able to fix the clock, launcher, and TWRP... (or at least TWRP and maybe the front LCD clock...)
** Google Play Services not stopping... working fine with this rom...
thinking I'll do the same with my T95Z box....
Thanks messerchmidt, optiknerv and jerry98vert for mentioning that I'm not the only one having issues with the "Unfortunately, Google Play Services has stopped" error a minute after EVERY bootup. The Google Play Store app works normally when I manually launch it ... BUT it's the Google Play Store background process under Cached Processes which crashes a minute or so after bootup. I notice by looking at the lights on my router, at bootup, when the initial download stops (what ever that is) then Google Play Store crashes. As if the download or update or something wasn't successful. If I disconnect from the internet before I bootup, the error never occurs and the Google Play Store cached process runs as usual.
When I go into the Google Play Settings and click on Play Store version, it says a new version of Google Play store will download and install. I look at the lights on my router and see something is downloading but it never installs. I've tried this a half dozen times with no result. Also, in settings, under Device Certification in GP settings, it says "Uncertified",
I updated the Google Play apk to 7.7.40 (not to the latest ) and that didn't help. I even had issues installing the apk- > "App not installed" Had to use Lucky Patcher to install it as a system app.
I have spend over 80 hours trying to troubleshoot this over the last month. I've tried EVERYTHING except reinstalling the ROM. But based on what others have said, I don't even think it would help because it seems system apps are outdated or corrupt somewhere. And unfortunately, this is a dead-end ROM with no updates. I'd appreciate others' input as well. Thanks.
Google related apps I have installed:
Youtube (not the TV version)
Gmail
Hangouts and Dialer
Google App (quicksearch)
Brave Browser (based on chrome)
Also noticed other strange things like when I tried to sideload Youtube, it would install normally but when I rebooted, the app was totally uninstalled from the device. Also, one morning I noticed my Twitter account was removed from the device. It's quite possible the ROM or device has been corrupted?Last edited by jseeley; 31 May 2017, 00:59.
Originally posted by jerry98vert View PostI have the T95K Pro and I also have the google play store has stopped working. I did everything I know, even got the most current google play store.apk file thru apkmirror web site and updated the play store, this method has worked on my Beelink GT1. But has not worked on this box if anyone has a fix please share.
EDIT: My (default T95Z Plus) Google Play Services app is version 10.2.98 (434-146496160) and according to APK Mirror, that's for 240dip.Last edited by jseeley; 30 May 2017, 23:05.
Originally posted by jerry98vert View PostHere is my YouTube that I did on updating the play store.......but I am still getting the error, only on this box and I am very sad because I hate to see errors.
https://youtu.be/cwhrO4ElDxQ
I picked Google Play Store 7.8.16 and Google Play Services 10.2.98 430-146496160 because that's what my Galaxy Note 4 had and it's working fine.
I restarted a few times (Sunvell T95Z Plus) and didn't see the error come-up. I'd hate to open an app because I'm afraid the error will return on the next reboot because I'm so used to seeing it. I opened all of my Google related apps (Hangouts, Gmail, Youtube, Google App, Brave) and restarted and still no error.
What version is your Google Play Services? Also my Youtube version is 12.15.54 121554630 (regular app - not the TV youtube) Other things I tried was clearing out the dalvik-cache folder, Wipe Cache Partition, "Resetting app preferences" in the apps manager, removing google accounts.
Originally posted by Rickpub View PostNougat 7.1.1 on T95K Pro.... For what it's worth I installed the Nougat rom from the M92S Plus on my T95K Pro. Download link can be found here...
Thanks jewelry, for the play store I have 7.8.32 like my video, my play services is 434 version, but my Beelink are those same numbers. But I have 2 YouTube apps, that might effect my problem. I also have 2 google play store icon apps and I can't uninstall one of them, I think it has to do with the original launcher. BTW where is the location of play services so I can try different versions or did you just install the apk file by just clicking on it and installing it?
EDIT: WORKS PERFECTLY ON THE T95K , except for the front clock.Last edited by messerchmidt; 31 May 2017, 16:27.
just loaded this. will use king root and respond shortly
There are currently 1912 users online. 1 members and 1911 guests.
