[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Originally posted by superceleron View PostDont take me wrong i really appreciate, but no for now on that matter.
For anyone interested in the ATV port, T95KPro is just $56 USD gearbest , lets get the guy funded for one.
Originally posted by ashyt16 View Postsuperceleron
Thanks for the ROM, working great on my recently purchased T95Z plus.
I bought this item with wifi not working out of the box. After a little Googling and with the help of you and this forum it turns out the seller had installed the wrong firmware which was meant for the later wifi chip.
After installing your ROM everything is up and running and wifi working great.
Im an active XDA developer, so as pay back to the community I have compiled the latest TWRP v3.0.3.0 and added system_image backup. This allows your ROM to be backed up and restored. It also allows RAW system images to be flashed using the INSTALL button in TWRP.
I have created a TWRP flashable system image of your ROM, saves faffing with USB sticks and Sd cards.
TWRP can be flashed with an existing installation of TWRP or RASHR and then the SYSTEM IMAGE can be flashed with TWRP.
Hope somebody finds these useful.
TWRP_3.0.3.0_T95Z
SUPERCELERON_V1_FINAL_TWRP_SYSTEM_IMAGE
Thanks.Last edited by jseeley; 15 March 2017, 16:16.
Since the last time I installed this Rom about a week ago, I've seen the average memory usage go up without installing additional apps and I'm always clearing recent apps, cache and restarting. With a fixed amount of apps installed, I went from around 640mb (average 3 hr) to about 800mb with recent apps cleared and cache/memory cleared. The Android OS alone is using almost 500mb.
The first time I installed this Rom, it climbed from mid 600's to almost 900mb without installing additional apps and constantly clearing memory and cache which seems to have no effect in reducing the ram usage. That's why I reflashed the Rom, but the same thing is occurring again.
Would clearing the Dalvik Cache make any difference? What's causing this? Just a symptom of Android 6.0?
EDIT: I uninstalled 5 of my biggest apps and the 3hr average ram usage hasn't budged after a couple hours.Last edited by jseeley; 15 March 2017, 20:40.
TWRP_3.0.3.0_T95Z
Thanks.
Just couple of quick questions ashyt16
- Is this recovery image compatible with T95K pro ?
- Since this recovery replaces stock recovery, once installed via RASHR, can regular "stock structured" images like "Superceleron V1 Final" be installed or it will only work with raw system images ?
TIA
Originally posted by kwuw4sale View Post
Great to see custom recovery on these boxes
TIA
It should be compatible with any T95 device as they all essentially use the same kernel. So as long it boots and the configuration files are compatible then it should work fine.
I doubt it will able to flash the stock images, but I honestly don't know.
There are currently 3856 users online. 1 members and 3855 guests.
