RK3368 04/2017 True Octacore Firmware
Hi Shomari, i've tried ur rom and when on 1st boot it had Android logo and all "shaking" with some green lines going down as it was booting. after finished the boot it was ok but that green lines Wih "shaking" screen comes on when playing videos. Sometimes my screen turns all green and i have to force reeboot. I've tried to flash the update but it freezes when trying reeboot to bootloader with same app and all others i've tried. I even tried to factory reset and it freezes too. I'm stucked in this situation. Do u have a solution for this, so i can reeboot to bootloader or factory reset? Thx man
If you still have any lines or distortion on screen, which is rare but reported in some cases, it's usually due to 'disable hardware overlays' setting being set to on - turn it off. I turn that setting on automatically and some devices show adverse effects. In such cases, simply toggle the setting.
Originally posted by Shomari View Post
For reboot functions to work, install this kernel/resource combo once you've installed the full firmware http://ge.tt/7GKnMgj2
How do i install this?
I extracted the files and tried to install each IMG in "factorytool" but it give an error loading them.
I´ve installed then the MARCH UPDATE but box didnt reeboot with this update
I´ve oppened the box and found a reset button.Last edited by miiike; 27 May 2017, 13:22.
Hi guys, i´ve found the ROM for the V99 Star.
I flashed it with a male-male usb cable plus the Rockchip Batch Tool 1.8 RUS / ENG in py PC.
Download and extract the IMG
Instal the drivers for the Rk chip so it can be detected by Windows
Load it in the Rockchip Batch Tool 1.8 RUS / ENG
Open the box and press the reset botton and then with it pressed connect the other end of usb cable so the box can be detected. No need power source because PC gives you the power through USB cable
After box be detected and ready to flash, it will have a color square in the Rockchip Batch Tool 1.8 RUS / ENG.
Flash it.
Connect box to tv.
Start it and have fun.
Firmware: https://cloud.mail.ru/public/Aywg/YKenvm6yu
Rockchip and drivers: https://4minipc.ru/programmy/196-roc...8-rus-eng.html
Originally posted by miiike View PostHi guys, i´ve found the ROM for the V99 Star.
Flash it.
Connect box to tv.
better you make a new Topic in the RK3368 Section like : V99Star Firmware , then post it .
So not many Users with same Box can find it , so please once more own Topic .
Better / greetings / gefattern
There are currently 2429 users online. 1 members and 2428 guests.
