RK3368 04/2017 True Octacore Firmware
Originally posted by dkholm56 View Post
great. You know I really had a feeling it was somehow related to recovery...Even TWRP is difficult to flash on this box. Even when I was able to boot into TWRP it would'nt see any partitions. May not be related but it was weird.
Originally posted by Shomari View Post
... then all you have to do is uncheck disable hardware overlays. I have that checked by default in my firmware. Or do you mean it happens when you leave it checked?
Thats when...
And yes its gone when i enable it (set to ON) but nevertheless it's a bug and that's what i wanted to report..You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by jit18 View Post
Confusion perfect!
Thats when...
If you use my full firmware, without replacing boot/system, that will always be activated automatically.
... so you have to check that, or not check that for it to work well on your box? You should also think about trying the latest Z4 builds (not the 4PDA one)
Not check... Then problem...
Is there a particular reason why you always activate this in your Roms?
Confusion perfect!
Thats when...
If you replace either boot/system, it will be off, and you'll have to re-enable it with every reboot.
That's not a problem with my full firmware, or if you don't replace boot/system.
That's one of the things I did was disabled hardware overlays programmatically to make it persist after reboots.
Originally posted by jit18 View PostBut this is always so...
I haven't seen any of these issues, including this issue with the apk installer and I use that all the time.
I'm gonna recommend you use the latest firmware for the Z4 I provided in this thread http://freaktab.com/forum/tv-player-...ctacore-thread
Flash the full firmware, then the images in the Z4 True Octacore archive.
Hi Shomari,
read the message, problem firmware Z4 4PDA with power supply 4A (stop playback at 4 amperage)
http://4pda.ru/forum/index.php?showt...ost&p=60592903
Use the new Z4 versions from here: http://freaktab.com/forum/tv-player-...ead#post641933
Other than that, I don't know what to say.
It's possible maybe the devices have different tolerances, if it's a Z4. You have to understand, I have two Z4 boxes and don't have this issue. Good luck..
Hi Shomari,
Anything new you want me to try regarding the M8 Pro recovery. Just checking.
thanks much
There are currently 2722 users online. 1 members and 2721 guests.
