RK3368 04/2017 True Octacore Firmware
Guest
Originally posted by Shomari View Post
I don't know which is preferred. I would guess the 'true octacore' if we went by number of downloads.
But that's assuming that would even be valid way to gauge interest and that the download numbers are accurate. So who knows?
As soon as I get a little more time I'll PM you.
You can always take the boot/resource/kernel from my firmware (or at least the boot/resource) and add it to whatever build you're making or putting together. If you have any questions about how something works or doesn't work, just let me know. I know some of these images are tricky compatibility wise.
Damn I was that close already last week
It's working... OC & T8C
BTW ... voice recording works with my rom with boath USB ports. tested with a USB mini mic and aLogitech USB cam.
And I saw that the following is missing in your sources. Maybe it helps.
init.rc
Code:# for usb audio chmod 0666 sysclassswitchusb_audio_playbackstate chmod 0666 sysclassswitchusb_audio_capturestate chown system system sysclassswitchusb_audio_playbackstate chown system system sysclassswitchusb_audio_capturestate
My contributions to the community
[ ROMs ] Z4 RK3368 - android TV (ATV) | MXQ PRO 4K - p201 - android TV (ATV) | Yundo Y1 S912 - android TV (ATV) not yet released
[ Tutorials ] Bootup logo Amlogic S912 devices | Redefine any Keyboard, Gamepad, Remote Control
Wow dude I'm pretty impressed about your work.
Will prepare right now some screen shots, with a some interesting information (may even you not know) about your outstanding power horses. every body wish to have on his horse-drawn carriage.
Guest
Originally posted by Shomari View PostThe voice recording works in the firmware but they say there's something going in with the switching back and forth of audio sources specifically with the Mele remotes that causes the mic to stop working when using soundabout..
Guest flash this boot, it includes the nodes mentioned above by cOOLio , maybe his suggestion helps, and it does come from the Ugoos rom so maybe it'll do it.
Guest
Originally posted by Shomari View PostGuest flash this boot, it includes the nodes mentioned above by cOOLio , maybe his suggestion helps, and it does come from the Ugoos rom so maybe it'll do it.
https://mega.nz/#!zUQhiBhC!y4TMvX3bl...CbwoHmndh01WLM
OK here we go.
Lets first start with the kudos.
Honor to whom honor is dueShamori T8C B+L1600 @ (Z4-RK3368 - ATV - V3.0 GSE) Shamori OC B1600 L1200 @ (Z4-RK3368 - ATV - V3.0 GSE) T8C @ AnTuTu 6.3.3OC @ AnTuTu 6.3.3T8C & OC @ Bonsai Benchmark 1080pT8C & OC @ Bonsai 720p
These yet not released pictures, are made for an tutorial to enhance 3D games, in case the game has no settings to change the resolution.
Stock Kernel @ Z4-RK3368 - ATV - V2.0 FSE
Here are my thoughts about my first test results.
[ 3D Performance ]
My current V2.0 release is fast and stable. But definitely not as fast as my upcoming "Shomari OC & OTC Ready" V3.0 release. But why are these Bonsai 3D Benchmarks better with my current V2.0 release? Maybe because I updated today also my OpenGL drivers, to the same newer version, Shomari uses in his Z4 4PDA rom!? This must be tested. But as I said already before. Shomari newest release for the Z4, looks already fast and stable. Ok, stable must be still tested in long terms. But it looks already promising.
[ CPU Performance ]
Shomaris T8C is real True OctaCore, thats for sure. But his OC version looks also pretty good, even if the Little Cluster is not at 1600 GHz as he promised. But bath version are nearly a the the same speed/performance. And you can feel this speed. Nearly every click on my remote is much faster and smoother then before. But lets come back to the T8C & OC comparison. The T8C feels a bit smoother, but that is a objective comparison. But the T8C has the shutdown bug. That's definitely a win for the OC version, because it hasn't this bug.
I will start right now with longterm tests (gaming, watching movies and all this magic shit you can do with these boxes). Ohh, I've checked already my whole house, to find a 5V 3K-5K A power adapter, with the right plug. But had no success. So I will start all my test with the stock power adapter. But maybe that's the best way to start. Because that's exactly what the most of the others users have.
Ill be back ...Last edited by cOOLio; 14 April 2017, 21:58.My contributions to the community
There has to be work to raise that performance, I think. Too low.
I never get less than 47,800 in anTuTu 6.3.3. I don't know what that Bonsai benchmark is but I'll run it on my boxes and check the results.
Still, I think some users would like the TV launcher version so it's a good option. Plus, it's good to see someone else pull for the users. I made a true octacore version of the Ugoos firmware, it's in the Ugoos thread. I didn't get a single post or mention of feedback. So I never bothered with it again, myself.
There are currently 2719 users online. 2 members and 2717 guests.
