RK3368 04/2017 True Octacore Firmware
Fixed the reboot bug, and made many enhancements and modifications. There will be a slight, insignificant drop in performance as a trade off to fixing the reboot bug. Still blows the pants off any RK3368 firmware.
Please test on Z4 - there should be perfect hardware compatibility. AP6330 devices should work as well.
Originally posted by Shomari View PostFixed the reboot bug, and made many enhancements and modifications. There will be a slight, insignificant drop in performance as a trade off to fixing the reboot bug. Still blows the pants off any RK3368 firmware.
http://4pda.ru/pages/go/?u=http%3A%2...Oj2&e=59692213
Tx. Will on weekend
Do you think your rom will work in my android tv??:
Hi WAIKIKI728 ,
try it , otherwise you dont know , important Backup your Data with TitaniumB. and copy Android/Data/obb Folder to SDCard.
With TB of course the same , to SD.
Do you have a Stockrom for Flashing , if it does not work ??? then you can try it.
good luck
gefatternLast edited by gefattern; 24 March 2017, 13:18. Reason: stupid Â* always pop up after saving the Thread
Hi Shomari,
Just installed the latest version. Working are Wifi/BT, LAN out of the box no need to install the resource seperately and power off awesome update thanks. Things not working now are display clock and orignal remote control, also when first installed the langauge is set in Russian. Thanks again for keeping our RK alive !
edit: there are more changesu also put back the option to enable developer options sweet ... im gona try some HEVC video and some games i will report later
Keep testing, in a day or two your device is next for a full port including display clock and ir remote.
I had them enabled by default because I disable hardware overlays programmatically and it requires developer options to be enabled by default.
Some feedback so far, speed is fastsome games not running are super mario run it asks to update google play services also latest SPMC release closes itself , i installed SPMC 16.42 that works ok. Also root is enabled by default
... Could updateing the google services fix Super mario run? ALso could you have a look at SPMC thanks again Shomari
http://4pda.ru/pages/go/?u=http%3A%2...Oj2&e=59692213Last edited by aliens; 24 March 2017, 18:59.
Originally posted by aliens View Post
But something is wrong, Kodi after a few seconds.Box turns off
The 'true octacore' versions with the power menu bug (unable to reboot/power off) run at full speed and have no stability issues and are very power efficient despite the cpu hack.
This build with the power menu fix is going to need adjusting so that users can run it with stock power supplies. It's possible it may never be as efficient. I don't know yet, it'll take time and testing to adjust it.
Originally posted by brickmojoccatz View PostSome feedback so far, speed is fastsome games not running are super mario run it asks to update google play services also latest SPMC release closes itself , i installed SPMC 16.42 that works ok. Also root is enabled by default
In seven months nobody has ever reported overheating with my firmware. Not once.
I have never seen overheating in any of my testing.
The firmware runs the cpu 696-1608 (although this release does not scale all cores simultaneously) and requires adequate power to run. That's all there is to it.
There are currently 2491 users online. 1 members and 2490 guests.
