RK3368 04/2017 True Octacore Firmware
Originally posted by brickmojoccatz View PostShomari the device boots but in previous version i could flash the resource you provided (resource-port.img) to get my wifi, bt and IR remote working. In this version after i flash the resource-port the box wont give any signal also the led display isnt working.
I may have to run separate branches, one for the AP6330 devices, etc.
Hi Shomari, ive opened my box to take some pictures of the hardware used i have the 2gb/16gb model. If u ever decide to port maybe these will help thanks in advance.
https://mega.nz/#!s0xTCQzI!KxynYgrB_...X1a35v9HKbwGLk
https://mega.nz/#!44hmwCoZ!o5w9VReaq...b6NE3EZW_SpqVc
https://mega.nz/#!gpJGWTpa!SxIbo_f_t...sytbp6_Swak_Ek
https://mega.nz/#!t4ZhkZRT!danmaUsNR...dOlpVXQ0w3qIyY
https://mega.nz/#!cw4UTaKQ!8q9R-Y_n3...rR7fhJzRprx76o
The last two pictures include the my desktop after flashing the resource-port. It became cropped i think. Something changed to the resolution in your resource-port?
Hi, I tested your Rom i68/R68 with FTMC and SPMC the Dolby Digital, DD plus, DTS and DTS HD MASTER:
In the best case the sound is in stereo and otherwise there is no sound . regardless of the setting in HDMI bitstream.
Please for the next test active the gigabit port, testing will be easier.
Thank you and sorry for the time it takes but I did not have much.
I just tested (UPDATED - Version 2.0).
With the default player I could read DD plus, DTS, DD true HD and DTS HD.
Test with FTMC and SPMC: DD plus, DTS, DD true HD and DTS HD does not work.
The problem would not come from kodi? ...
Ps: Ethernet does not work on i68G.
I need Ethernet for more test.
(i68G \ Yamaha RX-V465).
Ok I get boot logo andriod but tv screen jump and have blur. It boot in 720 to start for boot see on screen. But progress it at least show boot screen. And boot into start up. Change into 1080 still getting screen lines when hold mouss move. But is working. I test bit more today. Wifi no work bluetooth work.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
I forgot to add Ethernet again, sorry. I keep forgetting it because I don't use it ... bad habit of mine.
Originally posted by scooter2014 View PostOk I get boot logo andriod but tv screen jump and have blur. It boot in 720 to start for boot see on screen. But progress it at least show boot screen. And boot into start up. Change into 1080 still getting screen lines when hold mouss move. But is working. I test bit more today. Wifi no work bluetooth work.
Originally posted by brickmojoccatz View PostHi Shomari, ive opened my box to take some pictures of the hardware used i have the 2gb/16gb model. If u ever decide to port maybe these will help thanks in advance.
Only AP6255/AP6335 devices supported in v2.
The i68/R68 will be getting its own update soon, no worries.
brickmojoccatz are you saying you got it to boot with v2 using the resource-port.img I made you from another firmware? Because if so, then I'll probably be able to port v2 for your device sooner.
Hi Shomari, it could not boot, it just lost signal but with blue led on. I made some pics of the mainboard. the second pic shows it used the AP6335. I have got a twrp resource img included from a friend who has the same box as me just all original. He gave me a TWRP full back up. I did manage to flash the twrp resource.emmc.win using adnroidtoolrelease.2.35 and the kernel from twrp too... hope it can be of some help... or if u need anything specific for me to do let me know, thanks again.
There are currently 1796 users online. 5 members and 1791 guests.
