RK3368 04/2017 True Octacore Firmware
Perhaps, my download was corrupted, but it installed and is working, but there are no apps. No Google Play Store, or any other apps, except the browser. When open the browser, I can't get back to the desktop. As, I suspected, my Ethernet and remote do not work. None of the icons at the bottom of the screen work.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
If you could have a look at the USB ports that would be great, the IR remote isnt a big deal since im using an minikeyboard. My device is a chinese R68 shown in the pictures in this thread http://freaktab.com/forum/tv-player-...device-r68-1gb i have the 2gb/16GB model. Im using a combination of v3 of this rom http://freaktab.com/forum/tv-player-...hardware-clock in combination with my original resource img i flashed in twrp.
Do you think getting the clock display working would be possible thanks in advance.
Originally posted by clarkss12 View PostPerhaps, my download was corrupted, but it installed and is working, but there are no apps. No Google Play Store, or any other apps, except the browser. When open the browser, I can't get back to the desktop. As, I suspected, my Ethernet and remote do not work. None of the icons at the bottom of the screen work.
Originally posted by brickmojoccatz View Post
Did you flash the wokring (original) resource img of your box to the resource parittion?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by brickmojoccatz View PostSo i know its really related to firmware specific. But i have some trouble playing HEVC h265 files in SPMC and KODI. Some h265 play fine and others just stay in the background not showing video. Is this an issue people know and have a sollution for? Thanks in afvance.
Originally posted by clarkss12 View PostOk, will try it again, will it cause the device to over heat? Also, without my kernel, I doubt I will have Ethernet, and my stock remote will not work.
I've even run builds at 1752mhz believe it or not. RK3368 is nothing like RK3288, which runs blazing hot. RK3368 scales up in freq just fine.
brickmojoccatz, I'll get your clock/ports working for you soon.
As to the icons, I've only ever heard of firnware sometimes having home/recent buttons not working, depending on how you flash the firmware and what firmware you're flashing over. Most installs are fine, but this happens on occasion.Last edited by Shomari; 13 February 2017, 01:23.
Originally posted by brickmojoccatz View PostShomari thanks for the great updates, im using the resource you posted in this thread. I think it has somethign to do with 10bit and 8bit video files but ill check a few of them to be sure and post back.
Originally posted by brickmojoccatz View PostShomari this fixed the usb ports and are now working. Hardware clock isnt working. Thanks for the update!
There are currently 2713 users online. 1 members and 2712 guests.
