RK3368 04/2017 True Octacore Firmware
Hi Shomari,
I have flashed your latest update to my beelink r68g and overall the firmware performance is very good. The only trouble is occasional sound stuttering in YouTube which often happens on these devices. Are there any adjustments I could apply to fix the issue, flash a different resource or something? Thanks for your great work!
I hate to say it, but the only reports I've seen of sound stuttering come from users with the r68. The only fimrware that's been reported to not have sound distortion/stuttering on the r68 is lonix TronZid firmware.
Have you installed that one to check the results? It won't be as fast, no, but I think it would be better to have good sound without distortion/stuttering even if you lose the speed.
Originally posted by shivattaque View PostI don't no, do you have a link For resource i68G please ?
To be sure that this is the right one.
@shivattaque
...aaah. Alright. You're almost there, you're doing the right thing. In that tool, at the same screen, you have to take one more step - click the square at the end of the row marked resource, and it'll open a file explorer window for you to select the path of the resource image you want to flash.
Quick reboot does not work.
Unfortunately kodi (FTMC and SPMC) are not usable because of the HD sound that does not work or makes a horrible noise.
Hdmi passthrough.Last edited by shivattaque; 19 February 2017, 12:31.
Hdmi passthrough.
And reboot from inside the system won't work. It's a bug in my code that's been there for the last three months
There are currently 2762 users online. 2 members and 2760 guests.
