RK3368 04/2017 True Octacore Firmware
hi,
You will take me for a draw but I can not put the "resource.img" with Android tool.
Would you have a tutorial for resource?
I try unpacking both firmware tonight. Yours 64 bit too so should be able get working with geek too.
To poster above i suggest look up how to use rk flash tool 2.3 you tube it easy once you see how to swap files for flash tool.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostI Yours 64 bit too so should be able get working with geek too.
...nope - it's only 32bit - I've only been able to run mo123's MM on my box and the performance is good but not as good as 5.1. So for now still keeping 32bit.
I figured out why I couldn't compile the geekbox fixes, I'll be uploading new tests tonight
Originally posted by davzar View Post
Dear Shomari, do you think that this resource would work on Wasser's Marshmallow firmware for my Beelink i68g, fixing the 5 ghz wifi problems?
I tried the resource, I got a black screen. Then i tested the rom / grapp 1.5.
It started but no wifi / BT.
I have not had time to do more testing yet.
I also sought the rom HPH NT-V8 ROM V1.6 by mo123
It is close to yours ?
Impossible to exit standby with the remote control and the light stays blue instead of being red for 2 roms.
Originally posted by shivattaque View PostI tried the resource, I got a black screen. Then i tested the rom / grapp 1.5.
Mo123's firmware runs well from what I can tell. It's very conservatively clocked, all the firmwares from HPH run with very low DDR/GPU speeds compared to almost all other stock firmwares.
Originally posted by Shomari View Post
After you flash the firmware is when you flash the resource to enable the wireless functions for your device. You won't be able to use your device remote unless you port it. I use an air mouse, no issues there.
I Tested but it shows me a word of errors and it does not work.
There are currently 2480 users online. 1 members and 2479 guests.
