For now you can stay on the ported version 1.5; I'll update yours soon.
RK3368 04/2017 True Octacore Firmware
shivattaque and others on v2, I'll post an update to the resource to fix Ethernet and some other minor issues I've noted in logs. Stay tuned and thanks everyone for your feedback.
shivattaque sonoman Andro_James DNIZoid Argaricolm
I've reopened the i68/R68 specific audio thread. Testers needed here http://freaktab.com/forum/tv-player-...ugh#post631314
Just if you can look at the ROM HPH NT-V8 ROM V1.6 by mo123, for now is the one where I had the best results in the HDMI bitstream with Kodi 18 Nightly Master built.
The problem on this rom is the screen scale of android which leaves black band on the side and the wake up by telecomande which runs under the rom of Ionix 9.5.
It is not possible to look on these roms to take what works better and put it on your rom?
Originally posted by shivattaque View PostJust if you can look at the ROM HPH NT-V8 ROM V1.6 by mo123, for now is the one where I had the best results in the HDMI bitstream with Kodi 18 Nightly Master built.
I try to help some device owners, such as i68/r68, which I don't own, but it's almost impossible to get testers.
You can use 1.5 on your box, 2.0 doesn't it yet, I'll let you guys know when it does.
Also, there is no IEC61937 passthrough in these builds. I posted a test version in the i68/r68 audio thread and maybe one or two persons tested it, if that. I don't have a receiver at the moment, if not I would've had IEC61937 in all my builds months ago. I can only go by what I see in the logs, and the logs look perfectly fine. The only tester that tried my experimental IEC61937 build was unable to provide logs, too.
Just stay tuned, folks. Thanks shivattaque for your feedback and tests!
Everyone using i68/R68 and ap6330 devices please flash V2 and this resource and let me know if it works on your devices. Trying to port it over. Please use the images provided and only flash this resource to test the port and report back. Thanks in advance
Originally posted by Shomari View Postshivattaque sonoman Andro_James DNIZoid Argaricolm
I've reopened the i68/R68 specific audio thread. Testers needed here http://freaktab.com/forum/tv-player-...ugh#post631314MK808B K.I.A.
MK908 Finless ROM 1.7a + Mele F10
CR11S Quickshot V3.1, 720p kernel @1,7GHz, GPU600, DDR720 + Mele F10
MK902 Quickshot V3.1 1080p @1,8 GHz, GPU 600, DDR720 + Mele F10
GT-I9505 OMEGA ROM
Hi Shomari and fellow RK3368 users,
The v2 resource port made your firmware boot my device and i must say its fasssssst. The things working are wifi (im confused cause when i opened my r68 box the chip shows ap6335), Lan is working too. Things that are not working are Bluetooth it just auto disables itself when i enable, the remote IR controllor not working and the LED clock isnt working.. I will try some 10bit HEVC video files later and give u the results. Thanks again for this resource port my box is flying on your firwmare.
edit: Also i dont see the build number under about device to turn on Developer options. Did you remove that for a reason i just wanted to turn off the scailing or set it too 0.5 for minimum lag.
edit 2: SPMC latest Beta SPMC-16.5.82-spmc-1bce08a-armeabi-v7a.apk plays HEVC 8 bit perfect but 10bit HEVC just stays black but audio is playing.Last edited by brickmojoccatz; 27 February 2017, 10:18.
For me i68G (6330):the wifi does not work, and i have no sound HD in Kodi 18 / SPMC 16.5.5 juste stereo.
log:
Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
I no longer have all the options (DTS HD, HD True HD, DTS) on Kodi and SPMC I have DTS but not DD Plus.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 2366 users online. 1 members and 2365 guests.
