RK3368 04/2017 True Octacore Firmware
Originally posted by gefattern View PostHi dkholm56 ,
try it otherwise you dont know , if you have a orig.Firmware and can Backup your Data ,
why not ???
good luck
gefattern
E:failed to mount /mnt/external_sd
Formatting /data....
and then went to a blank green screen..
has anyone else seen this before. I would love to try this rom on my box. I do have the stock firmware to re-flash if something goes wrong.
Originally posted by dkholm56 View Post
Thanks for the reply. Gave it a try and it flashed 2.0 without error. When I connected back to the TV it came up with the screen with the penguins on the top and then with a black screen that had
Use this one if you have ap6330 - http://ge.tt/3lizBOj2/ | it's the latest and most compatible. You may need a stronger power supply, some boxes do, good luck.
thanks
Great. Will give this one a try and report back. Thanks much for the reply. One more question if I may....what should I use to flash? The Android Tools?
thanks
thanks again for your reply. I do have the stock firmware btw....in case you were interested in taking a look at it.
Hi dkholm56 ,
not nice to hear , the only thing you can try is to flash parts of your Stock FW , like "Boot.img" or "kernel.img... ,
but ONLY if it is Lollipop too .You can unpack your Stockrom with AndroidTool "AdvancedFunction""Unpack" .
Flash the single parts with AT and try it again.
good luck
gefattern
Hey, I wanted to say thanks for your work on this ROM. I am running it on a EKB368 box but I got it on Amazon and it's branded "Yuntab" lol. I was able to root it very easily, just installed SUPERSU from the Play Store and it was able to install the SU binary without loading into TWRP. I was going to ask about the reboot function seems to be missing but I saw that in another thread.Last edited by burlinski; 07 April 2017, 00:31.
Originally posted by burlinski View PostHey, I wanted to say thanks for your work on this ROM. I am running it on a EKB368 box but I got it on Amazon and it's branded "Yuntab" lol. I was able to root it very easily, just installed SUPERSU from the Play Store and it was able to install the SU binary without loading into TWRP. I was going to ask about the reboot function seems to be missing but I saw that in another thread.
There are currently 2460 users online. 1 members and 2459 guests.
