[ROM] Beelink GT1 / Alfawise S92 SCV9A-ATV Version
    Missing drivers.....
    If I have some problem to pair ps3 controler, is this means that I don't have the driver on it. Where can I found this driver?
    Also I can pair a bluetooth remote but if I don't used it since 10 minutes, I lost the connection with the box.
    Any idea?
      Any idea?
      i think i added PS3 gamepad(really cant remember...), but you need to use cable... it wont pair by BT!
      And that is normal disconnecting... its a powersave feature, mibox also do it on their bt remote!
        Hi everyone,
        Sorry for the noob question, but i don't understand much about Rom's and the differences between them.
        I have the alfawise S92 running with the SCV8 Rom, with no problems.
        Is it worth updating to the SCV9 rom?
          What Kind of Drivers i have to search ? How to fix that quickly ?
            Originally posted by PDomingos View Post
            Hi everyone,
            Read the first post to see the changelog
              how do i change the splashscreen? Compiled png? What partition?
                Can anyone give an answer how i can connect the pc to the gt1 (android offical image) with usb cable?
                I'd like to develop apps on it (like on phones/tablet) but adb cannot find the device. I'd like to use without net so adb <ip address> is not ok for me, only usb.
                The usb debugging is already enabled in the developer settings and I've tried it on both ports. I don't understand why the device isn't detected
                  @superceleron
                  Any chance of compiling the ff-memless.ko xpad.ko modules for our kernel like done here http://freaktab.com/forum/developmen...780#post552780 to fix the left dpad power menu problem, and flashing led on the wireless 360 controller ?
                    Originally posted by tillaz87 View Post
                    @superceleron
                    hmm i will check it out, the problem is not the driver is the beelink firmware they simple dunno what come to their head decided to use the 704 etc key to other stuff... crazy...
                    The led i will check that source and compare with s912 since that patch is for s905 dunno if they made more changes to the code from them to now!
                    I did found a solution for beelink firmware some time a go, but you need to use xposed!
                      Hi, I installed [ROM] Beelink GT1 / Alfawise S92 - 2/16 - SCV2 BETA 7.1 ( 9377 Wifi Chipset ) but of course Wifi and BT don't work. I now want to install SCV9A-ATV 6255 ROM (BT FIX) but USB Burning Tool no longer picks up my device. Is it possible to install the new ROM another way?
                      EDIT: After a few tries I managed to get USB Burning Tool to recognise my device.
                        COOLEME MB3 (S912 / 2 go RAM / 32 go ROM)
                        i have installed ATV rom (22/02/2017) on a COOLEME MB3 (S912 / 2 go RAM / 32 go ROM) and it works fine on first reboot
                        take the fist link (for 9377 Wifi chipset)
                        direct link : http://freak-tab.de/luis/Beelink/SCV9A-ATV-GT1.zip
                        Remote control work on first reboot. no wifi problem
                        installed with microSD 8 go and BurnCardMaker 2.02
                        if it can help other users ..
                        For those who want original firmware with no "Google play services has stopped" problem, here is the link of newest firmware (SKU551117 QII_114M0_MB3) :
                        https://mega.nz/#!A9UmAZ6T!j1A_IIEo5...ZCqPiXJHeJSxWc
                          superceleron I tried installing this ROM via burning tool v 2.0.9 and It said successully. Later its booting into TWRP only. its not even getting detected in burning tool now. Can some one guide me here. What shoudl I do?
                            I now only have TWRP installed on my GT 1 device. How can I install this/other ROM please help.
                              @superceleron Its continue Superceleron V8C Rom? v9? Or its other rom.
                              Alwafise s92 stock rom. I hope try your rom
