[ROM] Beelink GT1 / Alfawise S92 SCV9A-ATV Version
    Hi SuperCeleron,
    I just installed this ROM on my GTI.
    I'm having the same issue I had a few days ago when I installed the First ROM on My Mecool BB2.
    can I get the normal looking Google Play Store?
    I realize now that it's probably not the ROM I should have put on it.
    but, I liked the other one so much I didn't think Twice..lol
    now please tell me there is a Regular ROM from you, with a normal Play Store and not loaded with all these TV apps I can put on my Beelink GTI.
    thanks
    Edit: I'm an Idiot for making the same mistake twice!
      Hello i've got a few questions.
      1.Could someone describe the full USB Burning Tool process (what options to check? Normal Erase? Erase bootloader?) Consider i already have latest stock rom..
      2. This FW is not prerooted right? If so how can i root it?
      3. With Superceleron kernel (latest version) is Green screen problem fixed?
      Thanks in advance!!
        Hello, first of all Sorry for my bad english...
        This rom is perfect, I love Android TV but I have a problem with cache kodi....
        When I play a movie by torrent, for example, a 16 GB HD Video...kodi only buffer the free space of internal storage, it does not cache in external drive...then...if I have 3 GB of free internal memory storage, kodi buffer only 3 GB, and kodi stops of playing...
        I didnĀ“t had this issue with Android V8B rom...
        Anyone knows if this is a problem with Android TV??? Could I cache on external drive??
        BIG BIG THANKS
          BIG BIG THANKS
          Did you format the drive as internal storage?
            Hello superceleron, not.... I use usb as external storage as I did in your SCV8B Rom, only problem with ATV
            Torrent client download in "USB/Android/org.kodi.com" and kodi let me do it
            Is very strange....
            Obrigado
              Is very strange....
              Obrigado
              Well since i dont use torrents.... maybe someone else can help you on that!
                thanks, anyway I think is a ATV limitation
                  Hello superceleron,
                  i see you do a very good update for your scv8c! Will you do a similar update for atv?
                  Thanks a lot for your good job.
                    Originally posted by killer0692 View Post
                    Hello superceleron,
                    really have to stop asking these kinda quesions he release so many. When he does he does.
                      Hello,
                      Why do I get a few errors when I do factory reset?
                      Is it normal?
                      Below attachment.
                        Yes is normal!
                          Tried to flash with m12n s912 wifi6255 firmware. So far so good, wifi working, no problem encounter. Just a quick question how to change the youtube recomendation? Or is there other apps that i can use instead of youtube in leanback recommends channels? Thanks again.
                            Hello!
                            Can I play touch-only games (Lara Croft Go, Ski Safari, ...) with a USB mouse with this ROM on a Beelink GT1? I cannot play them with the stock ROM, not even with Tincore keymapper. Something touch-related must be missing.
                              Hello superceleron
                              Will you be updating FTMC to version 17 and your next update?
                                nop, 17 sux....
