[ROM] Beelink GT1 / Alfawise S92 SCV9A-ATV Version
    Will this rom works with S96 Tronsmart S912?
      Yes it should looks like the specs are very similar to this box. But like always flash at your own risk.
        Specs is always the same....but wifi module is always different.Tronsmart is using Qualcomm wifi.Anyone tested?
          Hello,
          Thanks for the ROM, works good until you remove the LAN cable before start the configuration wizzard. After that all works perfectly.
          I have used the first version of the rom with my A912 >> No Wifi. Can anyone upload the wifi package please ?
          Btw i found that the quality of my movies are less good in FTMC as my old popcorn hours A200 player. Anyone have a good configuration for FTMC player ? (Like director shattered during filming the movie)
            Great ROM. Please support 3 GB RAM version and led (my box is m8s plusii 3g ram).
            Language is changing after reboot
              sorry if this has been asked, but how do you get rid of the super celeron recommendations row?
                You need to delete this folder "LeanbackCustomizer" in "system/priv-app" reboot to recovery and do a wipe on davlink/cache and cache reboot and there you go!
                TO ALL I WILL RLS A FIXED BUILD TODAY AS A TEST ROM!
                  updated 2ยบ post with a fixed bt fix(i hope) version for the A912 - 6255
                    Updated 1ยบ post with the SCV9A
                      Heyho,
                      have try your SCV9A Rom with GT1, connected with ethernetcable and.:...
                      it works like a charme! )
                      thanks a lot SC
                        Originally posted by ceth View Post
                        Heyho,
                        thanks a lot SC
                          Works good ! Just one thing : The led don"t show off in sleep mode. Can you expland how fix this ?
                            you cant... i know the led dont turn off in sleep mode i need to fix it.. again..when i have some free time
                              I have try your SCV9A Rom with GT1, connected with ethernet cable and it works smoothly
                              Thanks sc
                                Thanks sc
