[ROM] Beelink GT1 / Alfawise S92 SCV9A-ATV Version
    Some test rom for the ones that have problems.When testing and reporting plz say t5, t7 or t10 and the box brand (Beelink or Alfawise) ok!?
      I must say. I have this installed on my yoka kb2 and aside from no wifi or Bluetooth. This rom works fantastic. This made my box great....again: ).You rock super celeron: )
        LOL nice
          Hy, is there a way to get back to stock fw? I need the wifi for now. On gt1
            Where is the A912 VERSION please?
              When it is ready, then it will be posted, so keep your eye on post 2, where you will see it at the appropriate time.
                Check 2 post.... is there 2 test versions for the A912
                  GT1 A version on UGOOS Kernel - no wifi
                  Downloadnig the other one.
                  The one with superceleron kernel is OK, wifi works, both frequency bands 2.4 and 5ghz.
                  The wireless setup in the wizard still needs to select other language than en.
                  Also i recomend setting it up with phone/pin, is way faster.
                  Google play works, even if at first in the wizard gets an error.
                  Thank you.
                  A bug:
                  When enabling BT it gest BT Share has stopped at infinity, and only works with reboot. *maybe with stock kernel will work this too.
                  Now the question still is how to revert to stock?
                    Ok thks i will remove it!
                      Originally posted by dppinhal View Post
                      Hello!
                      1. Where can I remove the youtube videos and SC sugestions (HBO...)?
                      2. How can I put permanently my app's and widgets in the main screen ??
                      How can i organize all my app's in the main screen besides using the sideload launcher?
                        Settings->Home Screen .... easy ...
                          Hey SC,
                          have use your "MY KERNEL, GOOGLE SERVICES CHANGED AND NO SETUP" ROM. google service works only with WIFI.
                          it's a smooth ROM, works like your V8B. RGB Fix is also working
                          use it on Beelink GT1
                          many thanks for your hard work!
                            Installed the A912 6255 to the MXIII-G II using SD card and installation and configuration was a breeze with everything working so far.
                            Edit:
                            Youtube playback is awesome with colour reproduction simply breathtaking and as smooth as can possibly be.
                            I did notice that the very first time that I clicked in the Youtube search field with my mouse that you had to click on the very bottom of the field to activate the keyboard and the characters entered only show to top half of the character but after entering just a few the field reset itself and was as expected.
                            I don't get how the customisation of the apps row works. When I enter it I get the row of apps to organise but no way that I can see for re-ordering them.
                            And yes, the brightness fix isn't needed because it's spot on out of the box so to speak.
                              Hi, i can test them in The weekend.....
                                Edit:
                                In order to organize the apps row you either hold down enter or the okay button on the D-pad of your remote while an app is highlighted. You can also go to setting Settings / Home Screen / Apps and games row / Reorder apps row. Then one of the apps gets highlighted by default and you move left or right depending where you want to put the app. So using enter or the okay button on D-pad does the trick mostly. If you have the original remote that would help out a lot.
