[ROM] Beelink GT1 / Alfawise S92 SCV9A-ATV Version
    Tested for a few hours on yoka kb2.
    Pros: 1: colours are spot on
    2:the whole systms runs smoother than ever for me.
    3:kodi never worked better. In fact best quality with quasar (set the buffer to 100) and its the best experience I had thus far...VEEERRRRYYYYYY smooth.
    4:CEC WORKS AS IT SHOULD. when the tv is off i can turn the tv on just by pushing the power button on my android remote!!!! YES IT ******* WORKS!!!
    5:I did some gaming just cause I felt like it...and best experience ever ...AGAIN!!!
    Cons: 1:No Bluetooth or wifi (but those can be extracted from a yoka rom...anybody any tips on getting them drivers imported??)
    2: you tell me. I have had absolutely non of the issues everybody has been having.
    Keep up the awesome work super celeron.
    Im so glad I almost wanna pull out the wine and tell my girl to break out the red panties.
      T5 version working perfectly in beelink gt1.
      Installation fine
      Wifi, ethernet, BT fine
      Samba server fine
      Performance soooo fine
        Thks for the tests guys
        I think i found the problem of my kernel and setup not working... at least in my S92 is working fine without any hangs
          I think im going to try to fix the wireless on that one after i do the V3 of H96 pro+.
          I have lots of stuff to do... i still dint touch my VIM damn... lots to do lots to do and so little time...
            Installed the A912 6255 to the MXIII-G II using SD card and installation and configuration was a breeze with everything working so far.
            Edit:
            Youtube playback is awesome with colour reproduction simply breathtaking and as smooth as can possibly be.
            I did notice that the very first time that I clicked in the Youtube search field with my mouse that you had to click on the very bottom of the field to activate the keyboard and the characters entered only show to top half of the character but after entering just a few the field reset itself and was as expected.
            I don't get how the customisation of the apps row works. When I enter it I get the row of apps to organise but no way that I can see for re-ordering them.
            And yes, the brightness fix isn't needed because it's spot on out of the box so to speak.
            Yes i already notice that, still trying to figure it out why it does that!
            But on the remote its ok!
              Hi guys,
              It's my first time trying to mod my gt1 version A. I install Twrp on sick and I'm trying to install the atv rom with Twrp but in getting those errors :
              Running boot script...
              /sbin/post recovery boot.sh process ended with error : 17
              More lines...
              And then
              Could not find meta inf/com./google/Android/update-binary in the zip file
              Error installing zip file
              Could you guys help me?
              I don't have access to a pc, I have a mac so I can't use the burning tool...
                Here is the version for the S/N: A912 - AP6255 wifi chip
                Is missing the one with the stock beelink kernel i will do that one later, if anyone wants it...
                Unfortunately Google Play does not work ... so that the rom unusable ...
                  What google play? games? playstore?
                    T5 not working on my GT1 S912 even with two factory reset : Google Services crash in setup. I'll try the original one.
                      If the original dont work, you have the T7 and T10.
                        Hello superceleron I'm really enjoying your new room, superb on A912, so far. I need some apk and I would like to know what siteyou consider safe to download them. In apkmirror I can't find NOS tv or Vodafone TV. Tks! Do you prefer Sagres or Super Bock
                          Hello superceleron,
                          I have bad news from my test with t5, t7, t10 on GT1 S912 (using ethernet). I got error "Unfortunately google play services stopped"
                          It is very strange, because I had no problem, when I tested ROM "Beelink GT1 TVStock Nexus ROM (Android TV)" created by Magendanz. Is that possible to get help from Magendanz?
                            Installation fine
                            Samba server fine
                            Hi juancabu93, how did you get it worked on you Beelink GT1 S912?, because I get error "Unfortunately google play services stopped"
                              @nakah: unplug your LAN-Cable bevor! u load the Setup. i have test T5 and googlesetup is running only with WIFI.
                                Use the Aptoid that is in the rom
                                Sagres
