[ROM] Beelink GT1 / Alfawise S92 SCV9A-ATV Version
    Just installed SCV9A, and everything is working perfectly so far, what an awesome job you have done, thanks for all the heard work you've put into this.
    I can finally​​​​​​ say, for the 1st time owning the gt1, I'm happy with this device! I really like the TV interface.
      I'm going to try SCV9A on my GT1 A912 but I'm really pleased with this rom! I can't stop playing with it! Congratulations Superceleron! Muito obrigado!
        you welcome guys
          Hi !
          Thanks for the rom ! :-)
          Is there a way to remove the video from the notification ?
          Is that this ?
          "You need to delete this folder "LeanbackCustomizer" in "system/priv-app" reboot to recovery and do a wipe on davlink/cache and cache reboot and there you go!"
          And is there a way to launch FMTC/Kodi at start ? I used "Start Kodi" but it's not available on ATV.
            Hi superceleron, installed scv9a on my gt1 and everything is working great. Thanks
              Hi, the issue's with brightness is present in this rom? We need to use the fix?
                superceleron Just installed on GT1 A912 via Burn card method. Did setup with my ethernet cable. After setup switch over to WiFi and everything works great! Thank you!!!
                Do you recommend using usb burning tool or burn card method for fresh install?
                  Originally posted by Vincs View Post
                  Hi !
                  Is that this ?
                  Recommendation tiles? "settings->home screen"
                  You choice!
                  you choice, the app is there if you need it!
                    everyone is happy (inclusive myself) ;o)
                    have send u a donate SC and thanks for your work!
                    greetz from erfurt ;o)
                      Superceleron, will be from this firmware for Beelink GT1 g912 (9377) version ?
                        Thks
                        yes it is for that box
                          really love this rom superceleron perfect fast and smooth. however on al your roms my most important app doesn't work (ziggo go) tv kabel app https://play.google.com/store/apps/d...om.lgi.ziggotv
                          i don't have root on it and the time settings are correct. do you have any idea?
                            They may have Android TV blocked like Amazon prime video...!
                              Installed last A912 Version and everything is working perfect..... Many thanks... You are great SuperCeleron....finally i like my beelink.
                              Only one thing... copy-paste or cut-paste text in google chrome not working.....but is not important....
                                On my A912, I've the brightness issue.
                                • I dont think its needs the brightness fix... i leave that to you guys/girls to decide... the control app is there if needed!
                                I will try the app to fix it. (I didn't think it was already installed.)
