The only thing that I noticed is that I cant find/get into the important menu settings in Adaway for whitelisting/blacklisting, add sources, etc. There is no settings option in the red /orange menu bar at the top anymore, it only says Adaway in top left and the rest of the menu bar is blank (on non atv version setting change options appear in top right of this menu bar.) I'm not sure if this is related to the rom, or if adaway just doesn't work properly in androidtv? I tried clicking the settings/menu button on the remote, but that does nothing either. Can anyone tell me if there is another way to access the settings?
[ROM] Beelink GT1 / Alfawise S92 SCV9A-ATV Version
Great work Superceleron, the rom is very good, thanks! Everything went smooth for me on Gt1, no crashing or google account issues. I went from V8b > ATV version via sdcard, erase bootloader unticked, Wifi install. Upgrade went fine, I didn't get the potential english keyboard problem with wifi setup that was mentioned in 1st post. I then continued the setup wizard and everything has worked fine since. Tv App repo has never crashed for me or caused any problem.
Originally posted by dannykarstens80 View PostHello I can't update my box from usb burning tool. Is here any other way for me to update? I am on version Scv8-fix.
http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s912/others-aml-s912/firmware-roms-tools-by/611261-rom-beelink-gt1-alfawise-s92-superceleron-v8b-rom/page33R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
For those with problems with google services, use wifi for wizard setup (at least unplug ethernet during language selection).
About my no-working-file-server, i´ve discovered that when google services didn´t work (when at the first rom installation I had ethernet conection), samba worked perfectly,... but with google account signed, no samba...
Use the burn card maker option. I drafted some instructions here.
There are currently 3065 users online. 1 members and 3064 guests.
