[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3A-ATV Version (DDR3 ONLY)
Originally posted by PaulieP View Post
Hi, did you ever fix the Install Pending issue with Play store?
How did you fix it? Since it seems to be a very common problem with everyone's roms and every time someone tries to make an ATV rom.
I want to fix mine too, is it permissions, DRM, or? Would love to know how to fix. Thanks
did anyone get a fix for the Install pending issue? i downgraded back to this Rom from SCV ATV 4 because my Ethernet Port stopped working on my H96 pro Plus.
This is the only rom that supports USB to Ethernet adapter and it works brilliantly. In fact, this Rom is PERFECT, except for the Google play store issue.
Any help would be greatly appreciated.
BTW, thanks Superceleron for your marvellous efforts with these roms.
Never had play store issues with any firmware. Though I have an LPDDR3 box and can only use V6 based firmwares.
don't know why you don't run the 1gb LAN port on the box.it does just fine on its own.
another thing if you use any usb driven peripherals, use a 5A power supply. Not all usb devices are low power, and along with SD cards, some will draw extra power when heavily used, especially when at boot up and auto anti virus scan is going on.
Originally posted by X92-2GB View PostNever had play store issues with any firmware. Though I have an LPDDR3 box and can only use V6 based firmwares.
This is the ONLY ROM that detects an ethernet adapter. That is why I want to use SCV 3A
The only problem with this ROM is the google play store issue. I have tried everything that the internet says and nothing works. clearing cache and deleting accounts etc.
I dont have any power issues.
Any advice will be highly appreciated.
There are currently 3752 users online. 0 members and 3752 guests.
