[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3A-ATV Version (DDR3 ONLY)
I brought H96 Pro+ from baggoot.com - http://bgd.by/1qixym
and after flash cant restart device I sometimes have to turn off the power to restart
Yes know problem.... i need to update all my ATV roms! (Painn....)
How did you fix it? Since it seems to be a very common problem with everyone's roms and every time someone tries to make an ATV rom.
I want to fix mine too, is it permissions, DRM, or? Would love to know how to fix. Thanks
Hello, i got the h96 pro not plus 2/16 q9377 running a h96 pro plus 7.1.1 my wifi is constantly disconnecting, is this rom compatible with my box how do i get to flash it. Is it going to fix the wi fi dropping all the time issue? Thanks ppl i'm very green on this and a bit of scared coz i already bricked 2 boxes by flashing wrong softwere
Sent from my SM-N9300 using Tapatalk
Don't you bother asking this ppl about anything coz if we are green on this we don't deserve any help i alreaby briked 2 boxes bro coz i'm green i asked help to tbis ppl on this forum on this very same page or what you call it and nothing they didn't even bother to say f**k *ff and i already posted for help some 3 times so bro dont bother asking if your not one off them they will just ignore you like they do to me but you can always thake the risk and flash and just hope for all go well and get a good out come, then and if then you may get help coz they will think you know someting about this and they may benefit by helping you, know the op that is a good guy unfortunately is busy with other builds and may or may not help it depends if he sees your post good luck brother i got the h96 pro 2/16 ddr3 model it flash ok don't erase bootloader if you try but is up to you it may or may not work
Excuse me sir. But your number one WAY OFF BASE. I am sorry that you feel so shuned and I get that when your frustrated its very easy to lash out at people that all do this for not one single dollar of your hard earned caah. Most times responses come quickly. But ill look threw the issues here in a bit. But Id really like your tone to get Lost really quickly.
In case you missed a earlier post you can flash the Tanix T8 Max rom its working on both ddr3 and ddr4 plus both models of wifi (Sorry this is for the H96 Pro plus only) I will look at his device because he says NON PRO. Add into this OTHER clones that have different parts then sometimes yes NO ONE CAN HELP YOU. We do however try are best. I cant tell you how many boxes ibe blow up fried and burnt trying to get working firmware on but its a lot. Just keep in mind also no one here put a gun to your head and told you to buy that device either.... Your comment actually pissed off even the developers that do so much. And yet i didnt kick you out.
Alot of issues with flashing are windows error based and or licences not installed into correct folder willing to help you but some reading and providing feed back will be required. Try the firmware i listed and let me know how you make out.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by hcardoso483 View PostHello, i got the h96 pro not plus 2/16 q9377 running a h96 pro plus 7.1.1 my wifi is constantly disconnecting, is this rom compatible with my box how do i get to flash it. Is it going to fix the wi fi dropping all the time issue? Thanks ppl i'm very green on this and a bit of scared coz i already bricked 2 boxes by flashing wrong softwere
Sent from my SM-N9300 using TapatalkMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
I have flash this Rom but i become an update error with a red Android File with a
Alfawise
H96 Pro+
3GB RAM, 32GB Flash
Edit://
i have test it now, it works
That is the first Custom from here that work.
For all they have the same problem:
1 .First time, i have shoot my HDMI Driver and no signal anymore only bluescreen
2. I have use the stock FW and have flash it with bluescreen, half hour later power of, now it works again ...
3. i have use another Custom rom, Problem here a update error message but not a bootloop
4. I use this one, update progress start nowLast edited by wolfsstolz; 30 August 2017, 20:11.
Hi superceleron,
First of all thanks for sharing Great rom, We have Alfawise H96 Pro+ TV Box DDR3 3gb Ram 64 GB ROM with Android 7.1
(https://www.gearbest.com/tv-box/pp_679359.html)
this ROM support this?
Btw guys i ended the support for this rom!
General info:
Most of issues with apps closing and reboots are temperature related. I placed the fan on top of the box with another two usb devices to the box and the box would become unstable. Take the fan off the box and it runs fine 50 - 60c. Place the fan at the bottom of the box and then its stable 47 - 50. Running 1080 videos and games no issues. My box is running GT1 Ultimate rom. Thanks to scooter pointing out the temperature issue.
Apps i used were beach buggy, showb, tv t, es task killer, youtube, Ftmc.
i have another same box coming from supplier free of charge. I also fixed my dead M8s box from the skills i learnt from the forum.
Thanks SC for the rom.Last edited by Kingmarth; 10 September 2017, 21:59.
There are currently 3995 users online. 0 members and 3995 guests.
