[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3A-ATV Version (DDR3 ONLY)
Guest
Guest
Originally posted by guineapig View PostIs the stock remote working on this firmware ?
Originally posted by guineapig View PostIs this firmware safe to flash has anyone been using it on daily basis ?
Originally posted by guineapig View PostIs this firmware safe to flash has anyone been using it on daily basis ?Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Hi, everytime I'm trying to boot img from SD card, I get Android Recovery. I tried Update from EXT, but it don't work. Can you help me, what I'm doing wrong? HDMI cable plugged in, pressed reset button, then power up. ThanksYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Rom works fine for me, Play store too although this is after just starting up so it 'may' not have had time to update itself yet if it is updating that breaks it? Otherwise I can install apps fine and only have to sideload the odd non ATV apps so all good from my point of view. Shame that Xbox one controllers don't work with it, xbox 360 ones do seem to be recognised but I haven't had time to check if it works properly yet. Thanks SuperCeleron for the great rom, makes a change from the usual!
Originally posted by fabiancz View PostHi, everytime I'm trying to boot img from SD card, I get Android Recovery. I tried Update from EXT, but it don't work. Can you help me, what I'm doing wrong? HDMI cable plugged in, pressed reset button, then power up. Thanks
Can you help me, what does it means? ThanksYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Guest
I tried another SD card burned by Burn software on Windows (previously I was burning by Ether on Mac), but it didn't work again. Android logo with red X when I power up my Alfawise h96 pro+.
This tutorial helped me
http://androidpcreview.com/how-to-us...firmware/3749/
The USB port you must use is the one next to power port
Install the USB Burning Tool
Then Open it
Shutdown the TV Box
Press the recovery hole with a pin then connect the power adapter cord
Connect the USB Type A Cable and then release the recovery press pin
You will see HUB2 and connect success
browse the rom file
the default opton of erase flash (normal erase)
erase bootloader must be checked
and start
Hi, you guys know how to install magisk manager on this firmware. I tried to install magisk but keep getting installation error everytime I hit the install button. I choose dev/block/root as the boot image location. If you guys knew how, pls let me know. Thanks
There are currently 3156 users online. 0 members and 3156 guests.
