[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3A-ATV Version (DDR3 ONLY)
Finally, I received my Alfawise H96 Pro Plus 3/32GB device. Look good, I opened and I see a little radiator on the processor and 4 USB ports (2 must cut box for access).
The firmware seems to be from December 2016. I don't know if this it's the last original version, but, I want to save somehow this firmware.
If I try another firmware version and I'm not satisfied...can I return to original firmware?
Thanks for the rom . It looks really great . But I have fee questions hope you can help me with that.
1. How do I remove youtube notifications from the bar on top ?
2. How can I change youtube video from recommedation list to videos I like ?
3. Why there are no internet browser in this rom ?
4. Google play store is different from other play store which webare used to from other tv box . Also there are not too many apps in this store. Like google drive . I have few apks stored in drive which i want to install on the box .
5. Can I just roll back to your V2 if I want to change rom in USB burning tool.
Otherwise its a great rom but just feel like it's a bit restricted.
Originally posted by arico1234 View PostThanks for the rom . It looks really great . But I have fee questions hope you can help me with that.
Originally posted by superceleron View PostHere it is the AndroidTV version for this box.
Enjoy it
DO READ THE BUGS SECTION TO AVOID UNNECESSARY QUESTIONS....
Changelog SCV3A-ATV:- Fixed PS3/PS4 Gamepad support (needs cable)
- Fixed Xposed that was broken
- Added 4K Youtube Support (only works on 4K Tv's)
- And some cleaning...
Wife is already ready to kill me for messing around with the TV box all the time trying to set it up. (I understand you can't help me with this)
2ยบ you cant, "limitation" of AndroidTV, you can disable it if you like in settings/Home...
3ยบ install it
4ยบ yes it have less apps because is androidTV and only shows androidTV compatible apps, use Aptoid its in the rom!
5ยบ Yes
Hello, I've noticed something. When I look over ftmc movies, in dark sceneries, dark objects draw strong streaks. With the buildin mediaplayer is no problem. Someone else has noticed this? This is particularly pronounced in "Doctor Strange" first scene!
When I turn off the hardware acceleration in ftmc, the problem is also gone.
There are currently 1485 users online. 0 members and 1485 guests.
