this is the problem of having to many roms... something is left behind...
[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3A-ATV Version (DDR3 ONLY)
Originally posted by trungk43 View PostOne more thing, you can add "sys.display-size=3840x2160" to build.prop to have youtube 4k
Originally posted by superceleron View PostWeird... i dont have any led problems for real!
well i will be making a SCV3A to fix the gamepad and other bug that i found!
1º yes
2º yes
3º only sd but the mobile one, the androidtv one dont work on any non genuine ATV...
4º yes
check beelink GT SCV9A-ATVtopic its video there.in the 1º post near the end.. is the same rom +/-!
3 You're correct - I actually have a modded netflix apk for tablet that plays HD. I can share if you like.
4 I can open the app (leanback version), but It doesn't load any online music. Only the tablet version loads and plays online music and radio. Can you check if music plays?
1º yes
2º yes
4º yes
Originally posted by amitabh15v View Post
Okay so 1 & 2 are working for me.
http://199.175.53.21/netflixlatest.hdonly.apk (Force Enable HD only)
http://199.175.53.21/netflixlatest.ultrahd.apk (Force Enable UltraHD only)
http://199.175.53.21/netflixlatest.u...thdolby5.1.apk (Force Enable UltraHD with Dolby 5.1)
This is tablet version (not leanback) Netflix (modded). Not modded by me! So no responsibilites. Requires touch pad (air mouse) for some navigation. I found it here.
http://www.wetekforums.com/v/index.p...ar-android/p17
Will need to uninstall existing Netflix before any of this can be installed. Must have upgraded subscription for Ultra HD (4K).
There are currently 3158 users online. 2 members and 3156 guests.
