[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3A-ATV Version (DDR3 ONLY)
Great work SC! Flashed it last night and works like charm. I've been attempting to use Google Play Music & Netflix (leanback version) and they don't work, but I've been attempting those on many other roms and they have never worked. One question, you made a shortcut to netflix that shows up in Launcher. How do you make such a shortcut? I would like to make one for Chrome.
I have flashed it without major issues. After the first start I selected launcher wizard instead of home launcher. Is there any problem with that?
Also I have tried FTMC and at the first sight the picture is smooth. I need to test it extensively but is there any benefit using kodi 17.1 over FTMC?
Obviously I need to uninstall FTMC but if the smooth playback issue comes back with kodi I am ok to stick with FTMC.
Overall great work!
Originally posted by wwmoggy View PostGame pad connected I had push in the reset on the game pad first
Originally posted by trungk43 View PostLed and ps3 gamepad isn't working. Please fix. Thanks
Led its working just fine here!
Originally posted by amitabh15v View PostGreat work SC! Flashed it last night and works like charm. I've been attempting to use Google Play Music & Netflix (leanback version) and they don't work, but I've been attempting those on many other roms and they have never worked. One question, you made a shortcut to netflix that shows up in Launcher. How do you make such a shortcut? I would like to make one for Chrome.
Did you see the video? is there how to do shortcuts
Originally posted by futr0 View PostI have flashed it without major issues. After the first start I selected launcher wizard instead of home launcher. Is there any problem with that?
Overall great work!Last edited by superceleron; 28 February 2017, 17:00.
Originally posted by trungk43 View PostLed and ps3 gamepad isn't working. Please fix. ThanksAttached Files
There are currently 43114 users online. 0 members and 43114 guests.
