2º did you enable root? the app the controls the brightness need root to work, or just enable root use file explorer for to /system and edit the build.prop and change this line "service.bootvideo" from 0 to 1 and it should fix the issue!
3º i cant really tell since from my test on this H96's every one is diferente... on mine it boots in 10 secs, a friend of mine have one that boots in 25.... so its hw related!
