[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3A-ATV Version (DDR3 ONLY)
Originally posted by atboxshop View PostOk for the wifi, all you need to do is flash the wifi fix q9377 that comed with beelink rom. And for the remote, you need to copy remote and sc_remote files from ddr3 rom of h96 pro+ in the folder system/etc to same folder of ddr4 rom.
Hi, can this firmware be used on H96 Pro ( not plus )? It has 3GB/16GB on q6630 board. Same as R-Box Pro. Original firmware stated that it is Alfawise H96 Pro (Amlogic/q6330/q6330:6.0.1/MHC19J/20160920:user/test-keys). LAN was almost useless and wifi was unstable with stock. I've tried several fws. All of the healed network issues. Currently it runs with CSA93 ROM.
Can i flash this or V2 on it? Or is it for Q9377 only?
Originally posted by dynamic_d View Posthi super celeron. I have this rom installed on my brothers awesome box. we love it no doubt. however some apps like kodi for example dont show up in the recent apps tab....know how we can combat that if even possible?? Thanks in advance.
Cant do nothing about it, sorry!
Hello, I made flash by USB Burning Tool successfully .Then I disconnected USB cable and restarted my Alfawise H96 Pro+. But now it wont start. Blue diod lights, HDMI is connected, but display is black. There is no sign like "no connection". When I connect USB Burning Tool again and try to reset by toothpick, no device appears. Is my H96 bricked or is it possible to save it? THanks
In my experience, if the blue light is working, your good. You might try the SD card technique instead. My H96 Pro+ had a black screen, blue LED. Used a 4Gb SD card with a previously working firmware and waited. Seems like it took about 15-20 minutes but it finally booted up and ran as good as new. So try the SD card technique and let the box do its thing. Good Luck!
Originally posted by superceleron View PostIs
Well that is a problem on the ATV roms, they where never made to give access to that, i leave that on because i thought it was useful.. but it have some limitations, it wont show all open apps!
Originally posted by fabianczHello, I made flash by USB Burning Tool successfully .Then I disconnected USB cable and restarted my Alfawise H96 Pro+. But now it wont start. Blue diod lights, HDMI is connected, but display is black. There is no sign like "no connection". When I connect USB Burning Tool again and try to reset by toothpick, no device appears. Is my H96 bricked or is it possible to save it? THanks
or maybe add an ATV mode for your SCV rom~thank you for your rom~
There are currently 5087 users online. 1 members and 5086 guests.
