[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3A-ATV Version (DDR3 ONLY)
Originally posted by Wyle View PostSuperCeleron - I really like trying out your ROMs. But I lost something since switching from SCV3-ATV (Android 6.x)... to SCV3-ATV (Android 7.1) - The remote control on my box stopped working as well as it did with the Android 6 version of your ROM's. Is there a depository for your REMOTE Control files where I can download and test individual one's until I find one to my liking? In the android 6 version, even my ViZio TV remote could control my Android Box using the Multimedia keys. The Android 7 version ROM doesn't allow this. THANKS.
and i dint change anything that could affect the remote!
Originally posted by Akirainblack View PostATV is Android TV - Normal is just Android.
I do also have a question. It would appear that the system drops Wireless connection after a while but doesn't automatically reconnect to a known connection. Is there any way to make it do so?
hi sc. I installed your beta 7 rom on my box and it works great except I cannot go back to android 6. when I flash this rom i get a lot of erros but when it does flashes it stops and the splash screen. i keep staring at it for more than 20 minutes with no luck,. I tried reflashing but no success. any ideas why it wont pass the boot logo\?
You need to flash one of my A6 rom with erase bootloader ticked!
thanks for the grat work. Cheers.
Hello Superceleron and everybody
I have a problem after installing this version on my H96Pro+.
Unable to install any Google Play Store applications.
For example I tried Molotov and the status stays on "Installation in progress"... But the progress bar doesn't fill up.
Also tried with other applications, same problem
I've already searched on google for solutions.
I tried :
- clean storage and cache for google play store and google play services. --> doesn't work
- asking for manual update of applications to be sure there is no application blocking the process. --> doesn't work
- changing wifi by ethernet connection. --> doesn't work
Also this page doesn't help : https://support.google.com/googlepla...1402%2C6241400
Can you help me ??
In this situation, I can only install APKs. Nothing can be installed through Google Play Store
There are currently 3428 users online. 0 members and 3428 guests.
