[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3A-ATV Version (DDR3 ONLY)
    its not TFF its FTMC(FreakTab MediaCenter) and its a kodi fork maintained by me.
    Still no 7.1.2 for aml... i already rls a "normal"(not atv) of the 7.1.1 for he h96... but i still dont recommend it... A7 on aml its still full of bugs!
    Sorry about bad spelling FTMC :-) I didn't knew it is a Kodi fork maintained by you :-(
    I've intalled the 7.1.2 aml firmware but like you said, full of bugs and the big one is the overheat :-( With this aml 7.1.2 firmware my box freeze about maybe 2 hours usage... If i understand, my h96 Pro+ will never have A7 firmware ?
    I'm a professional graphist, if i can help for your splash screens and more, tell me ;-) My Book >
    L'univers d'un freelance créatif décomplexé dans un monde totalement ouvert et instructif. Conseils, astuces et infos pour tous les curieux connectés.
      it should!
      A question that I finish, which version do you recommend to me that is more stable at the moment for I use in the H96 pro + 3g / 32gb? I do not know the difference for this AlfaWise box, thank you
        I have this Box and the great custom Firmware of Celeron run like a charm on it ;-)
          Mine is 3G ram DDR3 / 32Go memory EMMC
            I also have this box, do you use this firmware: SCV3A? I'm using a 7.1 firmware and it really gets the box warm and sometimes it turns itself off. Thanks
              hmm the one that i used it even more recent, and the scv2(to be rls) its even more lol!
              But that is to A7 topic!
              Eu tentei instalar a ROM pelo sdcard mas apresentou erro. Apareceu o ANDROID com um X sabe o que é?
                Hello, I have the H96 Pro version plus 2g ddr3 and 16g ram. It is possible to update this version, I can not find. All I see is 2/32 and 3/32. Thank you
                  well it should work, but not 100% sure!
                  So if you try it, you do at your own risk!
                    Ok thanks, the post for version 7.1, I can not find it
                        Sorry wrong thread
                          Hey guys.
                          I flashed the rom about a month ago. It did work even though my unit is one with DDR4. The only issue, that I kind of noticed this week, is that I can't install any app. It always says "Install pending" without doing anything. Ever heard of this issue?
                            Originally posted by dabrain230 View Post
                            Hey guys.
                            Yes know problem.... i need to update all my ATV roms! (Painn....)
                              I'm stupid, I know...but...what is now the recommended firmware for Alfawise H96+ Pro 3/32Gb, DDR3?
                              I see a lot of variant and i'm really confused.
                              I have now oem firmware aml_s912_q9377-H96ProPlus(3+32)-20170308 and isn't stable. Sometime the system rebooting without motive just on the start. Another time freezing in Kodi.
                              Should make update to 7.1? Can I make update with SD Card to 7.1 version? I don't have USB cable.
                              Until now, I make it 2 update with SD Card without problem but I see here a lot of people who bricked device and I'm scared.
                              If it's possible, give it to me a quick answer because tomorrow I must go in the holiday and i need take the device with me.
                              Thanks a lot!
                                I tried now update with SD card with this firmware: aml_7.1_s912_q9377-H96PROPLUS_912_mac-20170602.img
                                After startting updating, I received this image? What can I do? It's bad?
