Solution for stuck in Android load AML8726-MX Dual Core TV Box Android 4.2.2
Originally posted by jellywobbles View PostJust one question - must the SD card be exactly 4Gb? I only have a 16Gb SD card. Is it OK to use this?
Originally posted by BenniBenassi View PostI think it works, it will make your 16Gb card a 4gb card (since it is an sdcard image of a 4gb version). After restoring your box, just use the Easeus Partition Manager to delete the 4gb partition and make it 16gb again.
Here is another question - once I have restored my MX2 clone & set it up how I want it to be - how can I make a similar image to the one that I am using now - so that this new image I made can be used on many other MX2 clones?Live as if you were to die tomorrow. Learn as if you were to live forever
To make this image I used official rom from Matricom.
Originally posted by BenniBenassi View PostOnly way that I know is to make a backup (either with cwm or online nandroid backup) and boot with CWM and restore.
I have flashed MATRICOM_MX2_115_FULL_AUG_09_2013.imgc, but see that there is no XBMC installed.
What one do you suggest? With Hardware acceleration??
P.S. Does the Android Gadgets ROM have more apps installed?Live as if you were to die tomorrow. Learn as if you were to live forever
You can choose from OTA Update to update with Matricom version of XBMC or you can download from AndroidGadget. Both are hardware accelerated.
I use the AndroidGadget version. In my opinion this has more repos.Last edited by BenniBenassi; 21 September 2013, 18:11.
Originally posted by BenniBenassi View PostAnd voila: thus the thread .
I found your Thread at xda-developers
AND many reverences to it
Originally posted by BenniBenassi View PostUp to you where you spend your money....an now, I think it would be a little bit easier for me because of this =>
Because the crypted information is not very helpfully for me, I collect this information:
Android System Information:
G02REF => DroidTV MX , Tronsmart Prometheus (old)
G18REF =>Tronsmart Prometheus (new), a lot of China Manufacturer
MX2REF => G-Box Midnight MX2
GENERIC MX MEDIA BOX
=> it all describe the same HW (AML8726-MX with 1GB DDR3 and 8GB NAND FLASH and Ports) only different SW???
HD18 v2.2 and HD18 v2.21
=> is the information printed on the boardRK3288 Devices
- Overview BOX (LINK !)
Of causean now, I think it would be a little bit easier for me because of this =>
DroidTV MX (=g18ref) is the same as Matricom G-Box Midnight MX2 (=mx2ref).
Generic MX Media box or Android TV Box AML8723MX 8GB is the same as above g18ref.
They all have the same layout board and printed on board HD18 v2.2 and so on.
Prometheus is also unknown to me. Anyone with sure knowledge may post to clarify.
The looks of this box is this:
DROIDTV MX OVERVIEW
ROM FLASH GUIDE
Originally posted by BenniBenassi View PostLOL
Post results here. Should not take more than 10 minutes and you are set.
Then remember to make a backup BEFORE whenever you start to feel the need to "TRY DIFFERENT THINGS".
I then installed the Android Gadget XBMC hardware Accelerated (xbmcapp-armeabi-DroidTV-050713.apk) which is nothing short of amazing! Wow - it'll take a long time to work my way through this.
One thing that immediately strikes me about my Midnight MX2 clone is just how everything works! I also have a Minix X7 & this baby puts it to shame - end of! Streaming videos on XBMC is "gob smacking"
I am one very happy bunny!Live as if you were to die tomorrow. Learn as if you were to live forever
Originally posted by jellywobbles View PostHey Benni - everything worked 100%. Took about 10 minutes to burn the image onto my 16Gb SD card - you are correct - it was partitioned as a 4Gb card (easily fixed after).
It's ROOTED now. Make a backup with this when you have set it up as needed:
You can restore with the CWM.
Originally posted by BenniBenassi View PostGlad to know. Been there, done that, felt the joy
I did manage to get my SD card to boot into CWM yesterday, but cannot do it today!
For how long do you have to hold down the reset button, when you turn on the MX2?
I keep booting into the default recoveryLive as if you were to die tomorrow. Learn as if you were to live forever
So, now I've ordered my box...
We will see, when it will arrive at me...
At that moment some questions:
1. in Post #40 you wrote " It's ROOTED now.". Because of the "xbmcapp-armeabi-DroidTV-050713.apk"? And exists another method?
2. Is there any method to dump the Stock-ROM (before using CWM)
3. Exist any comfortable Flashing - Tool (probably not, otherwise the SD-way would not be necessary)?
4. Existing other interesting Images than the MATRICOM_MX2_115?
And BTW: why call the ClockWorkMod "ClockWork"?
Thanks a lotRK3288 Devices
....Is there any method to dump the Stock-ROM (before using CWM)...
+1 I would like to know how to dump a stock ROM alsoLive as if you were to die tomorrow. Learn as if you were to live forever
Originally posted by jellywobbles View PostObackup looks very nice - does it have to have CWM installed?
m_for_me;97626So, now I've ordered my box...
Thanks a lot
2) Unless you are rooted, NO.
3) The sdcard way is the most comfortable way. You can lay down during the process to avoid any tension to your muscles and bones.
4) YES. Check AndroidGadget rom on their web page.
There are currently 1826 users online. 1 members and 1825 guests.
