Hi
I have a MX box. My device has the g18ref board. however the reset button is in the Audio SPDIF hole.
Does anyone have any experience with this issue, where the box is rebooting in a loop after trying the procedure explained by Beni and on XDA developers. I used the 4GB card and used the program mentioned to write the image on the sd card.
After the two errors (which are common) I rebooted the system.
AFTER THE REBOOT IT GETS REALLY WEIRD.
(This is the main issue)
- I am no longer getting the MATRICOM Screen and instead i get a White screen and sometimes a Green Screen.
- The box automatically starts to install the firmware again (i guess its automatically booting from the SD card without pressing the reset button).
- if i take the SD card out after the reboot i have a BLACK Screen saying no signal on my TV. which means the box has power but it does not start and boot in to the android system.
- if i put the sd card back in it boots automatically in to the installation again without me holding the reset button.
I have tried everything but i cant get the Matricom image back which is now replaced with a Pure Lime Green Screen.
In order to change the screen from GREEN to MATRICOM i tried the two files for recovery also provided by the DroidTV (Mx2 recovery zip in the SD card which has the uboot file) MY BOX Boots but it is stuck on the Green color screen and does not move and take me to the recovery and i have to take the plug out and restart the unit.
I tried the Beni image again but the same issue of my system LOOPING.
IS MY BOX COMPLETELY BRICKED??
Also if i HAVE THE UART cables does anyone have the full guide to unbrick the system??
Please help in this matter :-(
