Solution for stuck in Android load AML8726-MX Dual Core TV Box Android 4.2.2
Originally posted by BenniBenassi View PostHere are an almost-idiot proof ROM by AndroidGadget Matricom Midnight G-BOX MX2.
Special SD card image makes your TV BOX (*) a Matricom G-Box Midnight MX2 TV Box device (ROM DATE = 9th of August 2013).
* = is following
G18REF
G02REF
MX2REF
HD 18 v2.2
HD 18 v2.21
1gb / 8gb AML8726MX / Meson 6 / M6
It is very simple to install, just insert a 4gb or larger SD CARD into Windows PC, use this program to set up the card: http://hddguru.com/software/HDD-Raw-...02Portable.exe
Then use the extracted sd card image file (of your choosing) as a source and set a target to your sd card (4 gb), it writes the image, close the HDD RAW COPY program and eject the card (SAFELY - choose eject from PC, right click menu + eject).
FILE: Matricom image Matricom Midnight G-BOX MX2 v1.1.5+ image (August 9th, 2013)
WARNING: THIS METHOD WILL ERASE EVERYTHING FROM YOUR MX BOX AND INSTALL A NEW ROM. USE AT YOUR OWN DISCRETION.
Matricom image (Android 4.2.2): OTA works for XBMC etc
- Make sure MX device is powered off and power cable removed.
- Insert SD card you just created.
- Insert a match or a toothpick to reset hole - you will feel a click. (AV hole in the back)
- Power on the MX box by inserting power cable, while holding the match in the reset hole.
- It will boot to recovery and start installing ROM.
- After finishing it will give 2 errors - these do not matter.
- Remove power cable and insert it again, the device will boot as MATRICOM MIDNIGHT G-BOX MX2
THIS IMAGE WILL ALSO UNBRICK THE DEVICE.
tried the above with no joy
box boots blue light
shows a9 logo
then black screen and red led on front?
T.I.A for any help
ps box is g18ref armolgic 8726mx_v1.1 20140410Last edited by Mudda_funkA; 05 June 2014, 13:29.
-paulschalkwijk I have tried many different firmwares, Prometheus, matricom, mx but neither have worked. For each firmware there are 3 files, recovery, factory and a zip file.
I also tried writing u-boot.bin and then created a partition using mini partition wizard to add firmware and this also failed.
what am I doing wrong and what else can I try?
Originally posted by 215HAN View Post-paulschalkwijk I have tried many different firmwares, Prometheus, matricom, mx but neither have worked. For each firmware there are 3 files, recovery, factory and a zip file.
currently, can you boot into recovery?
when using the tooth-pick method, sometimes it can take up to 60s before reaching the android maintenance man
Does your remote work when in recovery?
if not, try booting recovery with a usb-keyboard attached.
when in recovery, remove the sd-card (leave the mediaplayer on) and format it.
add the prometheus firmware, and re-insert into the mediaplayer (that should still be turned on and in recovery).
use your remote/keyboard to navigate to update from ext en select the prometheus firmware.
hopefully it will install
Originally posted by paulschalkwijk View PostDoes your remote work when in recovery?
BOOT LOOP OF DEATH
Hi everyone, ok so i want to add my contribution after reading the entire thread.
I dont know if my problem is the same as these last few posters who have detailed the android box to be in this black screen mode with blue light.
My problem is the same as most - switch on the unit -> no display -> blue light on the box -> does not detect any usb devices.
I create the special SD card (with every single image found on the net = matricom, acemax, IPTV18) and the box boots fine into the recovery screen (cwm). It will then automatically start to flash the firmware and it seems as it is working wel (takes about 5-10 mins to complete). I get 2 errors at the end one about the efuse mac address and another one. I restart the box and it goes again into the same process of flashing. I get at the beginning of every restart a red colour appear on the screen followed by a white flash then the flash process starts.
I think for some reason my NAND has become corrupt or the sd card cant create partitions for the box to boot properly. I dont get the A9 logo or any display with or without the sd card inserted.
Anyone can give me a theory to try or do i have to invest in a UART method (if so what do i need to do the UART method? has anyone done this successfully yet?)
thanks
me to....
Originally posted by kerikhaos View PostHi everyone, ok so i want to add my contribution after reading the entire thread.
thanks
i got the same problem....i also have 3 bricked boxes where the av button has no effect and im stuck on g box screen..... please help
Originally posted by m1pnk View Posti got the same problem....i also have 3 bricked boxes where the av button has no effect and im stuck on g box screen..... please help
There are currently 4565 users online. 0 members and 4565 guests.
