    Originally posted by soldiaz View Post
    Could you share the rom? I have x92 too LPDDR, kind regards
    No problems, I got the rom from DaivietPDA off his webiste here.
      Anybody know how to short pins in Nokia 2.2?
        it seems I am the first and only one with a Tanix TX5 Pro (S905X2) looking for the two pins ? :-/
        any ideas?
        thank you!
          Olá senhores, gostaria de saber onde encontro os pinos para curto desta placa.
          Por gentileza como unbrick está Box? Modelo: TAP PRO
          Tipo: Caixa de TV
          Sistema: Android 6.0
          Processador: Amlogic S912
          CPU: ARM Cortex-A53
          Core: 2,0 GHz, Octa Core
          GPU: ARM Mali-T820MP3
          RAM: 2G
          RAM Tipo: DDR3
          Desde já agradeço. Segue fotos.
              Can somebody help me find those short pins on Bqeel Y4 Max
                Dear All, I unfortunately bricked my device. Its transpeed t98 H6.
                I tried to recover it using Phonixsuite and PhoenixUSBPro but the stock rom failed at 62% and giving error download boot1 failed (0x161). The Phoenix Suites start whether we press the reset button in AV slot or not. Someone told be to try with Shorting of pins. I dont know the exact location. Need your help
                  My device x96 w s905w 2g/16gb is on bootloop. I am not able to enter even recovery. All methods failed to get out of the boot logo. The emmc is Samsung KLM8G2GEND-B031. The data sheet tells the the Rset-in pin is K5. But I am not able to locate the pin. I will be really thankful to any body who can help me locate the pins for shorting.
                    Not able to upload image. Getting error:
                    ImageMagick exec error found: convert: unable to open image
                      Hi, I discovered this board and this thread yesterday while looking for some information on which pins I should use to short-circuit my bricked X96 Max+ 4/64 (S905X3) but I haven't found the info.
                      If anyone knows which pins are the ones to short circuit, that would be much appreciated.
                      Thanks.
                        Thanks.
                        same problem here,
                          Hi guys, this board is a version from tx3 mini B4 but in s912(quadcore). I try install tx9S rom and "die" just show audio digital red light . No windows conection whit amlogic tools, no any signal where to make mask rom board cs_912_tx_b4_v1.0
                          I cant upload my photos o share on google....
                          Please help me
                            Finally, I want to try NAND Chip Mask ROM Mode Short. I would appreciate it if you let me know where I should short the pins. x96 s905x 2g 16g (q5x v2.1) 1415kae ( thgbmbg7d2kbail )Toshiba nand. I am not good at English and I appreciate your understanding. edit) Im happy.
                              Originally posted by xiaxi527 View Post
                              same problem here,
                              Those BGA boards are not easy to shorten, I am interested in the shorting location too
                                ...looking for some information on which pins I should use to short-circuit my bricked X96 Max+ 4/64 (S905X3)
                                short to GND...
                                source: [4PDA.ru]
