i use also Vortex rom, upload OK, after upload only Boot logo and thats all :-(
hello good night everyone. A short time ago I bought the tv box x88 pro 10, with a serial number x88 pro b rk3318 d4 v1.1 Now it does not turn on, a red led lights up and nothing appears on the television. I have seen in the forum that it can be reset by shorting somewhere. I wanted to ask if anyone has. I have installed the drivers with the program and it does not recognize me when I reset or USB. Do not connect the power cord I do not know if it is necessary or not. I am sending you a photo of what it is like to see if someone can help me. Regards, and thank you very much.
help debricking Sunvell T95 s1 2g/16G s905w,short pin NAND etc.
help debricking Sunvell T95 S1 2g/16g by short pin NAND,etc
The story is as follows:
Running stock android 7.1,it's rooted.Everything went fine.
I just wanna root management,so just intall SuperSU.apk,got it stuck at logo.Maybe installing Magisk.apk would not brick it?Someone explains?
So try to re-flash a rom by USB burning tool.Still stuck.
So try the card maker,this time.complete dark screen.Wiped bootloader.
So hook up usb-ttl to corrobrate to see in the terminal
'LOOP:8F;EMMC:800;NAND:85;SD:800;USB:8;LOOP:90;EMM C :800;NAND:85;SD:800;USB:8'
With card maker 'bootloading.....CPU reseting....'
Hit enter so hard,can't stop the bootloader....also it seems the rx port is somewhat damaged after a second soldering.
So the last resort shall be short pin NAND,right?
With Amlogic USB burning tool 2.1.7,without holding reseting buttonjust plug the USB,it shows connect successful,with or without Power adapter.Guess the RAM is DDR3L.
I read somewhere by short pin the NAND to instruct the CPU to ignore the existence of NAND.
Which two pins shall I short in my case?
What else can I besides short pin NAND to debrick it?
The two firmwares I tried is T95 s1 2G/16G
1. MBOXT0021_ATV.img https://chinagadgetsreviews.com/down...s1-tv-box.html
2. T95S1_2GB_TS10022.img https://forum.freaktab.com/forum/tv-...16g-p282-board
These two firwares always stopped at 7%.
My borad has a label that says T95S1-2GB-TS10024.
So maybe some change in specs?
Help.
P.S. installing ATV_s905w-V2H-final does nothing.
This forum has a problem uploading photos.
https://www.flickr.com/photos/jackeastland/50579025507/in/dateposted-public/
https://www.flickr.com/photos/jackea...posted-public/
Help.
Hello everyone , i have tanix tx3 and would like to know how to shorts pins in order to flash firmware.
https://postimg.cc/mcnhrNVmcnhrNV
Hello! Please tell me where are the contacts of the NAND chip beelink gt mini-A https://ixbt.online/live/images/orig...9b7b053a1f.jpg .https://ixbt.online/live/images/orig...81ae641e8f.jpg
There are currently 2816 users online. 2 members and 2814 guests.
