Originally posted by Vicky_singh86 View Postdid you find the pins to short,i have same problem.Last edited by Sama92; 05 May 2020, 03:26.
Originally posted by John26121981 View PostHelp to bring MXQ Pro 4K back to life
Thank you for allowing me joing that great forum.
I really need your help to make my MXQ pro 4K comes back to live . Story started when the box was stoped working and didn't boot or even had its Led on . So I plug it into my lap top tring to use hrad reset by toothpick , OTG usb port and downloading the firmware for AMlogic (thinking thats the correct chipset for that type of boxes as shown on interent). But the burning tool couldn't see the box . So I guess the box has different chipset and my guess was right so I used the tool for Rockchip and downloaded two frimwares for trial. the first firmware was upgraded but the wifi wasn't working then when I try the second firmware the box totaly diedno Led no detection on Rockchip tool. At the end I decided to open the box then was the surprice I found that the chipset is Toshiba I tried to short the pins but no luck . Please see attached photos for the mainboard so grateful if someone can help me to bring that box back to life.
Originally posted by kipir View PostYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by amitsan View Post
Downloaded latest firmware for my machine & burn it to card by amlogic burn card maker & inserted into card slot & power on the device .
Voila, recovery menu started & installing firmware automatically, without any pin short or any intervention...After 10 mins installation completed & device booted..
There are currently 1503 users online. 1 members and 1502 guests.
