Tanix TX9S 2GB/8GB Bought this cheapie just to experiment with. Tried a couple different S912 ATV roms LPDDR3. One worked (but many issues) and the next rom I tried bricked ihe box. USB burning tool would no longer recognize the box nor would it respond to a burn card. Shorting pins was my last resort and it worked. I was able to use the usb burning tool to restore the original firmware.
Hola soy novato en esto, necesito ayuda.
TVBOX GLOBMALL X1, deco se a quedado muerto, solo luz fija azul, no sale imagen.
NecesitarÃa saber en las patillas que tiene ,que se tiene que hacer el puente cuales son, para actualización con Burning tool.
No consigo que el pc detecte puerto del tvbox
Ayuda soy novato gracias de antemanoYou may only view thumbnails in this gallery. This gallery has 5 photos.5 PhotosLast edited by panitv; 13 February 2020, 16:32.
Hey all, I have an MX04-VO2 box, which is branded as Puersit 4K. None of those are coming up in google when I search the damn things, but it appears to maybe be a rebranded more common one?
The thing is fully bricked, with it only displaying a red LED on it. I have tried looking for firmware for this and tried to get it in recovery mode but nothing is working for me. I need to know what pins to short out on this to get it working. Please if anybody knows what is needed for me to do I would appreciate it.
Here are the numbers and letters I can find on the board.
2.3.60101 MX4N02000R
MX4N-V02 SP16120017
G161217 8G1G 1217
The Nand is named like this. SK Hynix 11270CG6T2EJR TCQCGE-610.
Thank you very much for your reply soldiaz but excuse my ignorance but what is a BGA board .I have succesfully flashed the box using the usb burning tool and also succesfully made and tried a micro card using a boot cardmaker but I still can't get my boxes to boot up. is there any other way to start them ? any help to get them to bootup would be greatfully accepted .when I say succesfull I mean both processes burning tool and card making were completed succesfully without any stoppages
Hi again soldiaz does BGA stand for ball grid array if it is I now understand your first reply a little better ( when you said its not easy finding pins ) but is it impossible to get this box to bootup without shorting the pins ie by flashing or burning card methods which I have already tried or is it just a case of just keep trying this way, or do I have to use the flashing and or burning method and THE PIN SHORTING AS WELL thanks in advance
So guys. On boards with BGA you need to look for two small round points. You need to short them.
For example : by the last picture I would try the two yellow points between the S905W chip and the grey/black 2R2 Resistor.
I found on the x96 Mini Q6X v 2.2 17355 2/16 with Samsung k4b4g0446q BGA Chips:
Hi antilkritz
could you please mark the pins or indicate which they are for shorting on my pictures above for the A95X F2 which has a BGA board I am not sure wheather you were replying about my posted pics or not in your post regarding last picture as the person above your post ( last picture ) had already solved their problem . please help and thanks in advance.
There are currently 2299 users online. 0 members and 2299 guests.
