    Nobody can help me please?
    I have the Zenoplige Z11 box. Inside is a TX3 PRO box (second photo).
    I tried to update the firmware with sd card and firmware tx3 PRO, but when reboot I see red light and it's bricked.
    I tried to connect it via USB with USB burning tool and I tried to short some pins without success.
    Inside there is a NAND FORESEE NCEMASD9 08G.
    Can someone help me with the procedure and pins to short to enter MASK Mode (so it is recognized by the PC)?
    Thanks, I hope you can help me.
      Try along the yellow marked stripe...gently try shorten pins until board gets recognized...Click image for larger version
        For my box this works:
        (image could not be uploaded, so this is why I make next post)
          Just short these pins.
            @ thelinhlge
            MAN !!!! it worked as you told!
            My fault was that I tried to shorten after cable has been plugged in!!
            This time I kept contacts on board with a fork and THEN connected USB!!!
            Thanks a lot!
            Btw.: device gets recognized again while plugging in so the fault depended on the tried firmware build...
              Originally posted by soldiaz View Post
              @ thelinhlge
              Thanks a lot!
                @ thelinhlge
                Thanks a lot!
                Congratulations
                did you flash your device successfully?
                  yes! back to life!
                    please help me to recognize Magicsee Iron (s905x) board - which pins to short
                    THGBMBG7D2KBAIL
                    TOSHIBA
                    MLC NAND Flash
                    update
                      Tanix TX9 Pro - Anybody knows which pins to short please?
                        letom gently try yellow pins. Shorten pins and while shortening connect mal-mal USB cable! You cant damage anything I tried almost any pins on my last S905x board :-P
                          TX9 pro has same firmware as TX92?? Hope you can revive..it is LP Memory...and mine refused to flash ..burning tool always exited at like 2%..
ID:	765884​Help me to find pins to be shorted, please...
                              I have found the correct pins (I hope), but windows cannot recognize the USB device. World_Cup device driver is installed already as I burned a firmware into the box before...
                                I point the pins - when I close them, my windows laptop do not recognize the box....Click image for larger version
