Hi there, PLEASE someone guide me so I can find where i'm wrong....
I need help to find what is it that I do wrong. I have a (mxq-4k)_1G8G_sv6051p_20161222 box that is bricked and I just can't go past the idbfail stage. I succeeded in getting it in mask rom mode ( even if I'am not yet sure what's the use of It) and then tried about every firmware I could find without achieving anything. I will admit that I've never been able to find any post,thread or else with the exact same # or name of my hardware. Its either not the same date or its the wifi chip or the board... anyway I am now asking here what I should have ask over 1 month ago which is HELP!!
I joining pics to make sure that I didn't make any mistake writing this. Thanks to all the one that have help or ask help because reading that many pages of trial/error-solution was really "knowledgeable"...
Yes english isn't my first language so I apologize if some of the line I wrote are affecting you.
Joce Do ItAttached FilesYou may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosLast edited by Joce Do It; 17 March 2019, 22:22.
Originally posted by Joce Do It View PostHi there, PLEASE someone guide me so I can find where i'm wrong....
Joce Do It
Once that is finished, connect your box to your PC, load your burning tool up like normal... start the RESTORE process with your firmware (not upgrade), and walk down every pin on the NAND until you get the result you desire.
Hope this helps.
-Captain Ben
Thanks for the pin advice, I didnt realize that I've might have push too much when I shorted it. As for the firmware I got the box from someone who was about to get rid of it.... So nothing came with it except the power Supply and a manuel that didn't explain sh** but that this box came with OS 5.1. Then should I try the restore with a firmware 5.1 or go with the 4.0 which is the original one for the first edition of the mxq 4k?
Originally posted by Joce Do It View PostThanks for the pin advice, I didnt realize that I've might have push too much when I shorted it. As for the firmware I got the box from someone who was about to get rid of it.... So nothing came with it except the power Supply and a manuel that didn't explain sh** but that this box came with OS 5.1. Then should I try the restore with a firmware 5.1 or go with the 4.0 which is the original one for the first edition of the mxq 4k?
Good luck and Godspeed.
-Captain Ben
Hi !
I Buy a male-male usb cable to recover my Mecool M8S Pro L LB (without reset button) but I don't find the right pin to short to connect windows. Can Someone help me ?
The NAND is Samsung KLMBG4WEBC-B031, AMLOGIC s912.
Thanks in advance
I already try the pins from those images but no success :
Sorry for my bad english, I'm french.
Originally posted by scorp76 View PostHave an Teclast p10 RK3368 tablet.Dead as it seems to be, caused by flashing wrong firmware..I have my doubts, but maybe it reacts in mask rom.
Busy to take it apart to take some pictures, here the info.
-Teclast p10 RK3368, with 32g nand.
-Nand, Sandisk sdin5c4-32g.
Also under the nand there are contact points, try to make some pictures from that either.Couldn't find much info about this chip.
Thanks!
Scorp
Uploaded the files, extension etc etc..
Will do it like this.
Underside, the 4 dots are under the emmc, nand chip.
the board arround the chip,
http://www.mediafire.com/view/aei4ck...212_182253.jpg
I also tried to find some datasheet for my nand chip, i think its this one..And according layout clk is pin M6...But i am to novice to translate it to what side and the right pin.Or maybe a contact point, hope someone can help me(see page 20). :http://html.alldatasheet.com/html-pd...N5D1-2G-L.html
Thanks , if they are not clear enough let me know, maybe it can bring it back.
Thanks!
1. download and run:RockChip_Batch_Tool_v1.8
connect usb wire from tablet to pc
2-3 second any sharp device hit in thats aria i show you in your pics. your pc recognize maskrom.
hit the restore in software.
برو برا بچه محلات تعریف کن.
There are currently 3518 users online. 1 members and 3517 guests.
