but either way, it would be good to specify which device you have?
syked69
The font on the box SCISHION V88 4K
Mainboard: XT-MX4VR-V1.0
Incorrect software installation does not see the computer device anymore
tried pins
5-6
6-7 ,
7-8
HELP MEE!!!!!
Originally posted by khn993 View PostNeed short location for t95z plus with SanDisk SDINADF4 - 32G chip
1) load aml burn tool
2) load known good firmware in tool (from box manufacturer)
3) click start 4) plug in usb cable to both PC and box
5) then Start shorting around this area. Can't tell you for sure which pins but I just worked my way up from the bottom
Originally posted by soldiaz View PostTry to connect power supply AND USB, then short!
To avoid this in future if I understood right, you must untick erase bootloader in AMLOGIC tool, then burn. If unticked device wont be bricked in case you chose wrong firm.
computer device but I can not find the original software MX4V on-V01
guess you need this: https://yadi.sk/d/weKOyhxQ3R9z4F
give it a try here: http://4pda.ru/forum/lofiversion/index.php?t763997-4240.html
[QUOTE=soldiaz;n759350]guess you need this: https://yadi.sk/d/weKOyhxQ3R9z4F
launcher stoppedplease others rom 5.0 Lollipop
1GB RamLast edited by ulas12; 19 January 2019, 17:04.
There are currently 2674 users online. 0 members and 2674 guests.
