Originally posted by anothertruth View Post
Same problem here, T95Z Plus 2/16. 2% Problem. Want the firmware file of the dead google drive link please. Thanks!
Guest
Originally posted by catalin0231 View Post
First of all i'm new here, and for some reason the tekst i typed was not saved.
My name is Chris, living in the Netherlands.
I just started to mess arround with these kind of boxes.
I'm trying to flash the box mentioned in the pictures.
Till now i Always get errors with writing to the box with USB Burning Tool :
[11:04:16 393][HUB2-6][Err]--[0x30402004]UBOOT/Partition boot/Initialize partition/Error result
Tried a different firmware, then i get :
[10:59:29 276][HUB2-6][Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
I even already tried to use the SD-card method, but for some reason i can't make the SDcard working.
The software BurnCardMaker is not writing to the SD-card, and is not able to partition it.
Is it possible to short the NAND, so i can write the firmware to it ?
or is the NAND broken ?
I also don't get any picture anymore on the screen. Screen stays black, and the blue LED on the front is lit.
I also don't know what firmware exacly should be on this kind of box. It looks like a rebranded MXQ Pro / Plus, but seems not to accept the firmwares.
Kind Regards, ChrisYou may only view thumbnails in this gallery. This gallery has 6 photos.6 Photos
Originally posted by DevilCry View Post
The problem is with the usb cable, it does not transmit the correct voltage. I bought the following usb in aliexpres and everything solved. https://www.aliexpress.com/item/Ugre...ceBeautifyAB=0 Try to buy one at a store that you know or on AliExpress. I bought it on Aliexpress because the seller that sold my tvbox, advised me to buy it. Choose usb 2.0
Good afternoon. Can anyone have information about which pins need to be short for Beelink GT1 Ultimate (SN B706) to flash it (the process freezes by 7%). The manual for A706 is not suitable, because when these pins are shorted, the device starts to "whistle" and reloads (checked for two B706). Thank you.
There are currently 1982 users online. 1 members and 1981 guests.
