    hello,
    I have a streamsmart s4 S805 1g/8g is that bricked, the wi fi has AP6330 imprinted on it. the motherboard is labeled DL4 V1.1. i will try to upload a pic of the board.
    I would like someone to tell which to short to clear the nv ram. i have an ota update in a zip file. does anyone know where i can find a recovery image?
    I am stuck
    any help?
      Prefix TX92-LP, motherboard CS_912_TX92_LP_V1.0, eMMC Samsung 32GB KLMBG4WEBC-B031. For Mask Rom close 17-18 pin
      Click image for larger version  Name:	IMG_20180104_150936.jpg Views:	1 Size:	179.5 KB ID:	701371
        are all the nand pinouts the same? my nand is SK Hynix, my board is an s805
          For the V88 Mini III wifi module SV6051P
          just short the 2 dot's in the picture
            Cross-posting here as well:
            Some help please? RK3229, 1gb/8gb, sv6051 wifi, XT-MX4N-V20 (either v88 or mxq-4k, see #427), PFF58-10AL NAND
              Originally posted by Rockabilly65 View Post
              Short pins MXQ PRO 4K motherboard R329Q_V3.0
              Under the N 8-9- or 9-10
              does not work your method tried almost all contacts is not connected
                have you tried 6-7 or 7-8 to at same time you hold the reset and power on, takes 1-2 seconds. I  use Android tool 2.35. You wish you had three hands, it's difficult but works
                  ураааа завелась но почему то только андроид 7,1 хочет на него вставать
                    cheers got wound up  but why is only the android 7.1 wants to get up on it
                      Android 7.1.2
                      very slow
                        Originally posted by dionisor View Post
                        Solved!!!!!
                        Instructions:
                        1. Install Usb Burning Tool 2.0.9
                        2. Load GT1_706D0_AP6255 FW file
                        3. Check:
                        Erase Flash -> Normal erase
                        Erase bootloader
                        4. Press Start
                        5. Short pins and wait until device discovered and program start.
                        Good Luck!!!!
                        Is this the same for my GT1 ultimate Click image for larger version
Name:	WhatsApp Image 2018-01-21 at 3.22.11 PM.jpeg
                          As anyone o knows the right shorting pins for Mecool M8S PRO L ?
                          Click image for larger version  Name:	image_30633.png Views:	2 Size:	246.6 KB ID:	703970
                          Hi friends, My x96 is hanged on red light, and its not getting detected by using Using Amlogic\'s USB Burning Tool with all possible combination of pressing the reset-button, plugging in the USB cable to USB OTG-Port and plugging in the Power, can you please tell me which pins to short in my Nand Chip, i am having foresee nand chip inside, Thanks.
                            tiku
                              Hello,
                              mine is a netbox V3 (s805) from Hexabyte (but seem simply be an ATV485 from Geniatech, see board rear view)
                              Anyway she not boot anymore since i flashed the eMMC with wrong firmware (see uart-console.png - no prompt).
                              eMMC (NAND) type KLM8G1WEPD-B031
                              socket FBGA-153
                              i guess the pins 17-18 have to be shortcircuited according some other posts based on other Samsung eMMC with same package FBGA-153;
                              but i would appreciate your opinions on this subject.
                              many thanks
                              Philip63
                              You may only view thumbnails in this gallery. This gallery has 5 photos.
