Originally posted by bugmenot2 View PostThis is the new box with no reset switch in them. Short pins to reset it?
XJH2018007
V89 0431
3G+32G+AP625?
? = Looks like another 5 cannot read the last character.
SD-8848WB 1803You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by bugmenot2 View PostIf you look at the second picture of the whole unit. You will see the top led and right in front of it the 3 pin is where the reset switch should be. I'm wondering if they are doing it to stop custom ROMs and things like that now?
Hi and first BIG THANX for all your work here!!
Ii have a MXQ Pro 2GB/16GB AMLogic S905W on a MXQ-S V3.0 board.
Tryed to change the Boot, Recovery, Rom and it works for a cupple of days perfect .
On one day the Playstore crashed all 5 minutes, later on the day my Stream and TV app crashed also. i uninstalled both and reinstalled both but nothing changed.
After that i go to the boot menu to make a factory restore and than the real problems began. Box is booting goed and after starting the android some apps crashed, some apps are lost.
Every restart needs more time, than it stoks at the bootlogo. I´ve tryed all to fix it but nothing works, no Burning Tool, no Burning Card Maker, no AML-Flash tool (ADB) nothing.
On the last point i even get a blue lamp, LogOn and 5 seconds later LogOff sound at the laptop and a Bluescreen on the TV.
So i searched for the Nand Chip Mask Rom Mode Short Location. Found nothing about my Chip so try for my self to figure it out and i get it .. he is back again Stock on Boot-Logo.
And here stopt it., get sound for LogOn/Off on the laptop and also see one new hardware in the management but could get a driver voor it, also the ADB client could not connect via Lan/Wifi.
Iam Sorry i dont remember with pins i connect, but it was te rush. next time !
Maybe anyone have an idea to fix my driver problem on Windows 10...
You may only view thumbnails in this gallery. This gallery has 7 photos.7 Photos
ola pessoal, sou novo aqui no forum...estou muito alegre por ter me cadastrado aqui, porque andei lendo vários posts e vi que todos estão bem fortes com o assunto. bom...estou precisando de um arquivo que possa colocar no batch tool pra ressuscitar meu v88 com placa mx4vr-v01, consigo conectá-lo com pc, coloquei alguns firmweres,mas não passa da primeira etapa e da falha.agradeço desde já aos amigos.
Hello everyone, I'm new here in the forum ... I'm very happy to have registered here, because I've been reading several posts and I've seen that everyone is very strong about it. Well ... I need a file that I can put in the batch tool to resuscitate my v88 with mx4vr-v01 card, I can connect it with a pc, I put some firmware, but it's just the first step and the failure. friends.
olá pessoal, estou deixando aqui uma firmwere altual para o v88 4k que ressuscitou meu aparelho via batch tool, depois de várias tentativas com firmwers antigos,a gearbest me enviou esse http://chiptrip.webok.net:5050/fbsharing/Cof3csGS e...SUCESSO!!!!!! OBS;(placa xt-mxvr-v01)
To unlock the box through the reset NAND chip, you can find the point by closing to the ground through a resistor of 200-300 ohms (10-20mA current can be calm that nothing is danificated) available contacts around the flash drive, Usually small capacitors and places where they are not soldered on the front parts of the board.
The box should be connected to the computer, the burning itools s running. Once you get to the right contact box, it will be decided. (From personal experience)
There are currently 899 users online. 0 members and 899 guests.
