Hello friends. Can someone help me? Tv box Docooler M9S-PRO 3 / 32gb s905x. NAND Toshiba THGBM5G8A4JBAIR http://cs5-3.4pda.to/13482168/THGBM5...db16a8ff8b4935 http://cs5-1.4pda.to/13361622/ 201807 ... 806edd2c5ed7e0 http://cs5-2.4pda.to/13361621/201807...367cc20230e1d8 http://cs5-2.4pda.to/13361620/201807...b87d9f1b8d380a
Originally posted by gidabytes View Posthi! i have a5x max+ 4g/32g Fn-Link 6222B-SRB wifi bluetooth module and did flash it on USB-4 right next to AV/reset. unfortunately, loader failed and now it is now bricked. tried the suggested short-pins but cannot detect the maskrom device. so m still looking for the correct pins to short to enter the mask mode and re-flash it. anyone knows this?
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by m4w View PostYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Guest
Guest
Originally posted by Alpetrus View Post
Which pins should I short in this chip?
Chip: SanDisk SDINADF4-32G
TV Box T95Z Plus, Amlogic S912, 3GB/32GB, Wifi LTM8830
I can not boot into recovery mode.
USB Burning Tool shows errors:
[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
or
[0x10302001]Romcode/Switch status/Check connect/Enum device
Thanks in advance for the reply.
one thing I got a say is ( once I got an in the main screen now after few seconds I get a blank screen ).
Hello.I opened the programUSB Burning Tool as an administrator .Android tv box not updating.Help! https://www.youtube.com/watch?v=mv0j...ature=youtu.be https://www.youtube.com/watch?v=8Hlw...ature=youtu.be Tv box Docooler M9S-PRO 3 / 32gb s905x. NAND Toshiba THGBM5G8A4JBAIR http://cs5-3.4pda.to/13482168/THGBM5...4dbf451f96edef http://cs5-1.4pda.to/13361622/201807...7354e25ce9ac51
Hi all, I need some help to unbrick my box. Sunvell T95ZPLUS-3GB-AP6255-v1076 (32Gb)
Cannot find a rom working on it and the board is different from pictures on the forum. Cannot locate the right pin for the short.
You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
T95Z Max pin location.
Mine is 2gb / 16GB.
FYI, I had to use an older laptop with a USB 2.0 port because it was failing to flash at 2%. Now flashed OK.
Oh getting this thing open was a pain, its glued together, you need to chisel around the seal with a screwdriver,
Thanks to the guy who suggested, power the device on, load up USB burning tool, select image and click Start. Then move around shorting the points near the NAND leave it 1.5 seconds for each one. This is how I found it.You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
There are currently 1113 users online. 1 members and 1112 guests.
