    Originally posted by mAtvXk View Post
    You have Allwinner device, not Amlogic, so use appropriate tools and guides - https://androidpctv.com/allwinner-fi...-guide-tv-box/
    Yeah, found out recently that I'm an idiot. Still, much obliged about the ports, I hope it helps somebody else.
      Originally posted by phankhanh86 View Post
      Here
      thank you it helped me a lot
        help to find the pin
          Help to find short point for mask mode
            Hello everyone, I need your help please. I installed the aidan rom and the os does not start and the reset button does not work to appear in usb amlogic burner. I would like to know where I have to shortcut to be able to install another firmware
              I need a NAND pin for my newly purchased DQ08 RK3528 device. Can you help me?
                Nice its even printed onto the board
                  Image gets blurry
                  when expand...
                  Try top right
                  In behind reset button
                  Will see to copper pads
                  Maybe is test point/maskrom ?
                  Happy Testing
                    Need help to find the pin on this board bm834_141_20473 v1.0
                    Click image for larger version  Name:	IMG_20231223_202135.jpg Views:	0 Size:	146.4 KB ID:	833712
                      You see copper pins ....just take screwdriver and test....
                        Originally posted by Bosko1122 View Post
                        Hello everyone.
                        Need some help. Does anyone knows where are located pins for nand short cut on Amlogic S905X2 TV box manufactured by SDMC, code name SDOTT0202 / DV8519, Quad-core 1.8 GHz (ARM Cortex-A53), ARM Mali-G31 MP2, RAM 2GB, ROM 4GB, NAND Samsung SEC 922 B041.
                        Photos in attachment
                        edit:
                        never mind. I found them. they are on the other side of board.
                        Can you mark the shortpins??
                          Hi ,
                          the Pins are mostly to find on the side with the triangle beside the pins ,
                          small stock Info ,
                          greetings / gefattern
                            Hello everyone . I have an Android box model HP4024- Amlogic S905X2, eMMC KLM8G1GETF-B041
                            Can anyone help me know which pins I need to short to enter recovery mode. Best regards​
