Any gurus familiar with the shorting procedure for this troubled specimen? Can anyone throw me a freakin' bone here?
Hello gentlemen, gentleladies and gentlenonbinary characters. I recently updated my Nexbox A95X (s905x chipset) to an ATVExperience ROM and now USB Burning Tool no longer loads the device. Samsung 622 klmag2wEPD-B031 emmc, AP6330.
Any gurus familiar with the shorting procedure for this troubled specimen? Can anyone throw me a freakin' bone here?You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by joe76634 View PostHi all need help to find which pin to short to get it to Mask Rom mode. Box is bricked/ no Os boot. see images for more info
Box : Mecool m8s pro 3gb/16gb model
chip : samsung 646
: KLMAG2WEPD-B031
IF anyone has successfully set it to Mask Rom Mode and detected by usb burn tool (also which version would be helpful), please reply, thanks.
So maybe you have to try the 2 I have in the red circle. Otherwise try any combination of the adjacent 4 pins.
You may have to connect the power adapter (at least that was the only option in my case). So the right order is:
- Start UBT. Load the image file. DO NOT press "START"
- Connect the cable while shorting the 2 pins. You may have to do this for 5-10 seconds before you get "Connected" at the UBT.
- Now connect the power adapter
- Now you can press "START".
****Use Usb Burning Tool version 2.2.0 https://mega.nz/file/E0MHyaDa#n5BHOV...RLgesKTiiuwFzY
Originally posted by ath156 View Post
Just yesterday I did revive a Mecool m8s pro plus 2/16.
****Use Usb Burning Tool version 2.2.0 https://mega.nz/file/E0MHyaDa#n5BHOVwobmWxLmfgnD9Bn8BWjjfH4RLgesKTiiuwF zY
No I used the usb port near the corner (not the one in the middle and close to the micro sd port !!). On the other hand I do not have the same TVbox as you (actually it is not mine but a friend's, whom I am helping - I will give it back to him today).
I bricked this Tvbox many times (probably more than 15+ times) because I tried any possible custom rom (mainly Android9).....sadly none of them was proper for this.....so finally the only rom that I was able to use was GI LUNN (7.1.2 AOSP or ATV)
Originally posted by ath156 View PostNo I used the usb port near the corner (not the one in the middle and close to the micro sd port !!). On the other hand I do not have the same TVbox as you (actually it is not mine but a friend's, whom I am helping - I will give it back to him today).
https://ibb.co/k0p8xV1
There are currently 2708 users online. 2 members and 2706 guests.
