    Originally posted by freddy View Post
    Okay
    Same img
    Underside of board
    Upper middle
    Cluster under CPU
    2 copper pads there
    no it not work
    but i found short pin....near 4R7 usb 2.0
      Originally posted by jalldoc View Post
      Tanix TX5 Pro, Amlogic S905X wifi 9377
      very esea....two hold near emmc
        Originally posted by phankhanh86 View Post
        no it not work
        Nice !!!
        Maybe repost img with indicators
        So can help others
        Happy Testing
          Nice !!!
          So can help others
          Happy Testing
          Short pin 1
            Skyworth Digital HP40A / HP4105-Intigral / S905X2 / NAND: SanDisk SDINBDG4-16G
              i have atv9 for 3229 but it lag, slow and lucher not same lucher atv (lucher mobile)
              who can help me make it faster and lucher same lucher atv 9
              thank somuch
              link file
                Hello, after root removal, device gets stuck on boot screen. How can I insert the short pin, can you help me? I think it's the same as the migu mg101 model
                S905L-B CPU
                  Xin chào mọi trong rom , nhờ mọi giúp đỡ , chạy chip rk3229, wifi sv60510 , up sai rom bị brick, đầu karabox k1
                    Bình Đinh Vietnam send to me unbrick
                      S905L-B CPU
                      thankyou
                        Originally posted by tteodor View Post
                        Hi again
                        I have problem with A95X F3 air .Only red light.Can samobody help pls?
                        Can somebody help? Here have answers for S905x3​ but i cant find short pins for this .
                          Hello, I hope you can help me, I tried to install another firmware and it blocked, only the green LED and the optical audio light turn on, I already tried with the sd card and it does not work, I also have a problem with uart but it does not recognize it very well, also with the USB cable to the pc but the pc does not recognize it, I attach a photo to see if it can help me
                          You may only view thumbnails in this gallery. This gallery has 7 photos.
                            Originally posted by SakiCZ View Post
                            Venz v12 Ultra SOLVED. Short pin in the area marked by soldiaz, exactly I do not know.
                            Found this gem from 2021.
                            1. Short ground and "pin in red circle".
                            2. Connect the first usb from the rear to pc (win11 in my case).
                            3. From power on the device manager should immediately pick up a new device, and the short is no longer needed.
                            Recognized: without driver "GX... chip", with "lib-usb32 usb devices" driver already installed "WorldCup Device".
                            Amlogic's USB Burning Tool's must be v2.*, and it comes with the driver.
                            One problem: after reflashing from armbian (emmc), in android a msg pops up asking for a "U disk to install BoardTest"
                            that doesn't let you do much, this havent come up after reflashing from coreelec, nor after failing android upgrade...
                            Device is still good for playing with other systems.
                              Originally posted by Bosko1122 View Post
                              Hello everyone.
                              Need some help. Does anyone knows where are located pins for nand short cut on Amlogic S905X2 TV box manufactured by SDMC, code name SDOTT0202 / DV8519, Quad-core 1.8 GHz (ARM Cortex-A53), ARM Mali-G31 MP2, RAM 2GB, ROM 4GB, NAND Samsung SEC 922 B041.
                              Photos in attachment
                              edit:
                              never mind. I found them. they are on the other side of board.
                              hi can anybody tell me where this board short pin...
                                DV8535​, Quad-core 1.8 GHz ARM Mali-G31 MP2, RAM 2GB
