I am looking forward to short the pins and then try uploading firmware.
Originally posted by virusviki View PostI have t9 rk3328 box 4+64gb. Tried upgrading the firmware and it failed which resulted in no power and no boot.
https://forum.xda-developers.com/t/t...-fail.4137369/
Friends, I am new to this post and I wanted to explain that I have a Mecool KM9 pro Deluxe tv box, and I have blocked the equipment after using a fake rom using the Anlogic USB burning tool method. Now the device turns on the blue LED but I have no video output and I have tried some methods to try to revive it, such as: burn card maker through the .img file. I would appreciate if someone could tell me where I locate the pins on the board using the short pin method and I can have the tv box with me again. Funny
raul.velis
Try the 2 pins inside the red square I have placed to your photo. These must be the correct points to short, but as always whatever you do you are doing it at your own risk. Good Luck.
ath156
Hi friend. I have a Mecool KM9 pro deluxe tv box that is
brick and I have tried to flash it with the USB burning Tool. I have tried with some android tv 9 stock roms, but it always gives me the same error 3%
Uboot/Get result/DiskInitial error
I want to try with an Android tv 10 stock rom, because it is the version I had before Brick was put in, the thing is that I have not been able to get any that is in .img to be able to flash it with the USB burning tool. Someone could port a rom prepared in .img and let it be ATV 10 for this tv box. I would really appreciate it if you could help meLast edited by raul.velis; 16 May 2022, 14:10.
There are currently 2002 users online. 2 members and 2000 guests.
