Use a short USB-A male to USB-A male Cable. Not type C. Also try different USB ports of your laptop (not all of them provide the same power !!!). Also if you are using a PC, better try USB ports at the back (beside the motherboard).
Originally posted by sasafat View PostHi guys, I'm so happy to have found such a thread, my device is also bricked. I wanted to ask myself because I couldn't find a photo or short circuit information of my device. I would be very grateful if knowledgeable folks could help with this.
R-box 4K - RK3229 Thank you all.
SOLVED
I found it myself I'm ,sharing it to help other people. Connect the otg cable while short-circuiting and pressing the power and reset keys.
Originally posted by JoseM View Post
Male to Male USB 2.0 (Type A to A) 1m and Male Type A to Micro USB Type C 1m
Originally posted by Hotrod1 View Post
I saw a guy take a screwdriver and start touching pins until he found the right ones and his box connected in a video. I would never do something like that nor recommend doing it. I just mention it because it would seem either he was extremely lucky or it's not as hard to destroy the chip as one might think. Probably a bit of both.i also remember when tv-box was working i coudn't erase the flash in maskrom mode this happened after erasing and flashing a few custom ROMs which were working fine till the last ROM which bricked the tv-box when i turn on tv-box there is no hdmi signal only blue light
now it's too late i guess i damaged the flash chipi also remember when tv-box was working i coudn't erase the flash in maskrom mode this happened after erasing and flashing a few custom ROMs which were working fine till the last ROM which bricked the tv-box when i turn on tv-box there is no hdmi signal only blue light
Originally posted by ath156 View Post
Edit: ath156 sorry my comment was meant for JoseM
There are currently 2704 users online. 2 members and 2702 guests.
