Originally posted by j0rdie View PostManaged to short the NAND for the Mecool KM8 P with the s912 chip and the Samsung KLMAG2WEPD-B031 eMMC. Originally the Amlogic burning tool was sticking at 4%, however a change of cable did the trick. So do persevere!
btw. when i only connect usb between pc and box, the box turns blue. So without power adapter connected.
used an old xp machine and it worked, now i'm with the black screen and only moving mouse cursor screen.Last edited by mark-1978; 14 June 2018, 05:30.
Please help me.
My x96 is completely brick.
The boot loader is destroyed and is not recognized at all by the burning tool.
Finally, I want to try NAND Chip Mask ROM Mode Short.
I would appreciate it if you let me know where I should short the pins.
x96 s905x 2g 16g (q5x v2.1) 1415kae ( thgbmbg7d2kbail )Toshiba nand.
I am not good at English and I appreciate your understanding.
edit) Im happy. As a result of testing one by one, we confirmed that if we shorted 5 and 6, we enter the mask rom mode. I fixed the broken x96 today.You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by daani928; 21 June 2018, 14:12.
I would aprecciate if someone could help me to recover a Mecool MS8PRO W that was bricked trying to update the ROM.
Not sure the reason, but the TV Box doesn`t response. The most I get is a green screen when insert original firmware, but doesn´t load anything.
I want to try try NAND Chip Mask ROM Mode Short. The chip (Samsung KLMAG2GEAC-B031) it seem to be the same recoverd by J0rdie, but the PCB shows a different layout most of pictures in this thread
I would appreciate it someone could lead to where I should short the pins.
Thanks.You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Guest
Originally posted by onevision View PostI would aprecciate if someone could help me to recover a Mecool MS8PRO W that was bricked trying to update the ROM.
Thanks.
Location for h96 H3 905 X Stick/Dongle Thanks
ricky divjakovski
Must use the port nearest to the tf card slot, Short h96 h3, plug in usb, i
1512719498433559.jpg Specification General Core: Quad Core CPU: Amlogic S905x GPU: Mali-450MP RAM: 2G RAM ROM: 16G ROM System: AndroidLast edited by trebor; 28 June 2018, 01:39.
There are currently 2753 users online. 0 members and 2753 guests.
