Ok. So, I just fixed mine! I opened her up.
Plugged in the USB Male 2 Male into USB Port 1.
Grounded pin 4 and 5 on the nand chip on the same side with the arrow. (could have been 5 and 6) and Windows recognized it again!
Then, I found the firmware files below which seem to be new and for S912C and S912LP that I couldn't find anywhere!
Credits go to The Real Dewayne @ http://www.batyoutube.com/watch?v=LyOr_qyL7Bk who posted these.
This is the new links to the newest firmware update install using guide in video. Use these links for the new firmware.
T95Z-3GB-912C
http://www.mediafire.com/file/l2j6he...4-16-v1076.rar
T95Z-2GB-912C
http://www.mediafire.com/file/h2ucgo...-GOK-ftest.rar
T05Z-2GB-912LP
http://www.mediafire.com/file/f3ssbt...-LPDDR3-2G.rar
T05Z-3GB-912LP
http://www.mediafire.com/file/u931ju...P-MG-v1076.rar
My Serial Number underneath starts with 912LP and it's a 2GB / 16GB Version.
I downloaded the T05Z-2GB-912LP firmware and installed it using USB Burn tool 2.1.6. It stopped at 98% and wouldn't boot, so I had to create an SD Burn Card and then voila!! It boots and i'm back up and running.
I hope this helps!
Originally posted by bugmenot2 View PostYes, Mine is still dead. It seems that they removed the reset button to stop others from flashing custom ROMs. The sad part is now I have a paperweight now.
Originally posted by DevilCry View PostI still have the same problem, it stops at 2%, can someone give me the firmware for my T95z plus ?. I attached photos.
Enviado desde mi HTC Desire 820 mediante Tapatalk
T05Z-2GB-912LP
Yours seems like it might be need the same firmware.
There is no reset button. I have it apart and the new ones don't come with one. The old T95z Plus boards were red (mine) and have the reset switch behind the AV port. The new ones are now green (mine) with no reset button behind the AV port.
There's a guide here ->[ https://www.youtube.com/watch?v=CUfKNNgxb9E&t=4s ] But he's trying it to load the SD Burn card which still won't work if you have wrong software.
I bridged in between each solder joint while powering on the box, starting from the tiny white arrow in the corner until the box suddenly was detected by windows when bridging between pin 4/5. I then used USB Burn tool to load the software.
Originally posted by mj1henry View Post
What's the Serial Number under the box? It should tell you which firmware for your S912 processor your T95Z needs. Mine said S912LP and I needed this firmware.
T05Z-2GB-912LP
Originally posted by DevilCry View Post!!!! PERFECT !!!!!! THANK YOU VERY MUCH THANKS, IT WORKS VERY WELL. How can I install the TWRP to get a copy of another t95z plus that I have more updated? So I can put that copy to this t95z plus, since the compilation of android that I have is more updated.
I have never tried flashing twrp onto a TV box but I saw a guide on xda forum. I think it's done using some amlogic software over a network directly to the box's IP address. Google for the "poison rom for t95z" and there is a guide somewhere around. Good luck!
Originally posted by bugmenot2 View PostNow it is just stuck in the USB on and off mode trying to flash now. All you hear is the USB connecting and disconnecting over and over. I think this one is dead and time to trash it. I hate it when a manufacturer takes parts out to stop you from doing custom stuff to your parts that you bought.
Sorry to hear that. But as I suggested, you should try grounding some pins on your nand. (I'm not sure if you have already tried that.)
Your box is already dead anyways, you've got nothing to lose
Glad to hear you got it working.
There are currently 3155 users online. 0 members and 3155 guests.
